Series/parallel wiring for three pairs of B200s
0 Members and 1 Guest are viewing this topic. Read 3189 times.
Luigi
  • Busa doing the business
« on: 27 Feb 2011, 02:00 am »
Hi Guys
Im wanting to wire up three sets of B200s to mate with my Alpha 15s. Already have two wired in parallel, so around 3ohms. But if I wire up another set it will result in a 1.5ohm load which my amp wont handle.
Is it possible then to series a pair of Visaton B200s for a 12ohm load, and then parallel the final B200 to make a 9 ohm load?
opnly bafld
Re: Series/parallel wiring for three pairs of B200s
« Reply #1 on: 27 Feb 2011, 03:07 am »
What kind of amp?
2 ohms all parallel or 18 ohms all series
2 series (12 ohms) + 1 parallel (6 ohms) = 4 ohms
2 parallel (3 ohms) + 1 series (6 ohms) = 9 ohms
Luigi
« Reply #2 on: 27 Feb 2011, 03:15 am »
A tube/hybrid chip amp from Aussie, the JLTI (just listen to it) Mk II, around 35wpc. Seems to drive a pair of B200s and the Alphas okay.
But not sure it could handle 1.5ohms.
Like what a pair of B200s can do and have another pair, like, hanging around, so thought I would bring them to the party.
Any thoughts on how I should wire these suckers together?
opnly bafld
« Reply #3 on: 27 Feb 2011, 04:05 am »
Pick up a 4th pair so you can series/parallel for a 6 ohm load or leave it as is and use the 3rd pair in another set of speakers.  :green:
S Clark
« Reply #4 on: 27 Feb 2011, 06:03 am »
Looking at the impedence graph for these guys, it look like they are closer to 5 ohms for most of the range that you are likely to use them in.  I think that I'd use 4 of them....
2 in series (10 ohm) paralleled to 2 in series (10 ohm) = 5 ohm for the group
Luigi
« Reply #5 on: 27 Feb 2011, 10:35 pm »
As it happens I have a fourth pair; is there some advantage to doing it the 2 in-series paralleled to two in-series way, over using three pairs per side, two in series and one in parallel for a four ohm load?
I realise there will be problems with lobing, peaks and dips and all, but given I have these on hand and it's not a big deal to OB the remaining pairs, I thought I should at least give it a whirl.
Besides, Im finding two pairs definitely better than one pair overall, so four pairs should be the bomb (using no good reasoning whatsoever).
opnly bafld
« Reply #6 on: 27 Feb 2011, 10:54 pm »
All 4 drivers will receive the same power.
With 3 drivers (2s+1p) the paralleled driver with receive 2 times the current.
With 3 drivers (2p+1s) the driver wired in series will receive half as much current.
To any professionals: Please feel free to correct my statements as necessary!
opnly bafld
« Reply #7 on: 27 Feb 2011, 10:59 pm »
Use a bigger inductor on 2 of them to roll them out sooner like a 2 1/2 way speaker.
Luigi
« Reply #8 on: 1 Mar 2011, 12:45 am »
I seem to recall that Danny from GR Research reckoned that chopping the tops off the full rangers and using a rear firing tweeter was worthwhile too, as it reduced the effects of comb filtering when using hordes of the same drivers.
opnly bafld
« Reply #9 on: 1 Mar 2011, 01:33 am »
Perhaps in this thread?
 http://www.audiocircle.com/index.php?topic=79482.0
To avoid comb filtering with multiple 8" drivers you would need a much lower x-o than what you have now.
« Last Edit: 1 Mar 2011, 02:43 am by opnly bafld »
Luigi
« Reply #10 on: 1 Mar 2011, 07:25 pm »
Can you be more specific? How low should the X-O point be approximately?
Luigi
« Reply #11 on: 1 Mar 2011, 07:39 pm »
Er, not not that thread. I believe it was in a thread relating to the use of 4 B200s in a line array. He mentioned nobbling the tops of all but the uppermost B200 to smooth out the response of the overall system, ie, to limit the effects of comb filtering.
opnly bafld
« Reply #12 on: 1 Mar 2011, 10:28 pm »
This might be worth reading (again?).
http://www.audiocircle.com/index.php?topic=70643.20
