0 Members and 2 Guests are viewing this topic. Read 28908 times.
I think this is highly subjective. From some of the reading and anecdotes I have read, any sort of ribbon/tweeter pairing can have a positive effect on the set up. JE Labs, on his website compared several 8" drivers, from olden WE 755As to other more obscure ones and especially in the different 755 comparison claims that tweeters can actually make a driver sound more balanced, with more low frequencies. Perhaps this is due that this midrange point and its output not comparable to the hi efficiency, increased output of the tweeter that from the listener's perspective, the midrangey driver actually "sounds" as if it is producing more lows. Furthermore, a member here in AC also told me about his experience pairing a 755E OB with ribbons and that it sounded fantastic. Nevertheless, you need to mate whatever you are thinking about introducing well with the lower efficiency elements.
I think it all depends on where its crossed. Although you will no longer be single driver.
Maybe you can help me understand how Zu does it so well?
Blasphemy! Depends on how sensitive you are to high frequencies and if it would "tilt" (weigh/bias) the presentation too much towards the higher frequencies. Try test tones and find out if you can hear much above 12,000 Hz (most can't).
