DAC-9
0 Members and 1 Guest are viewing this topic. Read 57121 times.
phusis
Re: DAC-9
« Reply #120 on: 11 Oct 2012, 08:16 am »
Change of plan:
It would seem there're no "ordinary" BNC outputs on the earlier named WCM-module/expansion board to my RME 9632 soundcard with the desired (internal) clock mode, so therefore I'm planning on upgrading my current RME interface with the Audiophilleo2 + PurePower USB-S/PDIF converter(http://www.audiophilleo.com/audiophilleo2.aspx), which provides a direct(i.e. without digital cable) BNC-BNC connection to my DAC-9. This is a newer developement briniging with it notable advances in jitter suppression.
ohlins
Re: DAC-9
« Reply #121 on: 13 Oct 2012, 06:14 pm »
collected the upgrade DAC 9...
