Well anyhow; Back to what this DAC sounds like.
First, I am a NuFORCE Dealer (as well as a High End Audio Enthusiast) so take my comments with that in mind.
Second, I demoed the DAC-9 at The Home Entertainment Show a couple weeks ago in a very simple but sophisticated system and it was spectacular. IMO it bested a couple rather hot DACs right now sonically and aesthetically.
Third, the Volume Control preamp section simply gets out of the way and lets the music through. As well the gradients on the Volume Control are small enough that you can get the sound pressure levels "just right".
Fourth, I just got a real chance to hook it up in my personal system and listen (which I didn't really get to do before the show) and all I can say is
WOW!! Cold and just plugged together, the system is elegantly simple:
OPPO BDP-93 transport>NuFORCE DAC-9>NuFORCE Ref 9 V3 Monoblocs>VMPS RM40 BCSE Speakers. All wiring is from Alex at WyWires and the same as I used at the show.
Again, all I can say is WOW. While it sounded good under show conditions too, it didn't sound
this good. If it gets any better (after warm up/which it is doing now) I might have to keep it in the chain and find greener pastures for my $5k preamp/dac. (which I consider one of the best in its price range)
Lots of things being done right with this DAC-9 in the chain;
Bass is deep, tight, clean and powerful. Mids are realistic and full without being forward. Highs are crystal clear and present without calling attention to themselves.
Soundstage is wide, tall and 3-D(eep) while images appear across the stage in proportional sized and fully formed sonic holograms.
If I had to "pick a nit" I would maybe say the remote seems a little lightweight, but it works exactly as it should and does the job intended.
If you're not getting the same level of performance, don't hesitate to contact me, as you do need to really read the manual to get the set up right (which I learned the hard way) but can also offer advice on if you need it.
