Port stuffers
0 Members and 1 Guest are viewing this topic. Read 2904 times.
Al Garay
Port stuffers
« on: 23 Mar 2004, 01:07 am »
I want to stuff the rear port on my 1801s. What material do you recommend? My wife is not to keen of me using my old undies.
I was trying to recall someone's recommendation of a plug they found in the plumbing section.  Trying to reduce some of the boom-boom that I'm not used to having.
Al
bubba966
Re: Port stuffers
« Reply #1 on: 23 Mar 2004, 05:51 am »
Quote from: Al Garay
So I'm guessing that old socks are out of the question as well?... :wink:  :lol:
Why don't you check out some of the cork plugs that Loewe's carries in the specialty fasteners section of the store? I don't recall what size ports your 1801's have as it's been quite some time since I've seen them. But they do have a fairly sizable selection of various sizes & thickness's.
Al Garay
Port stuffers
« Reply #2 on: 23 Mar 2004, 06:01 am »
I have to take my lawnmower in for service. So, I'll go check out the corks....
Thanks Bubba!
Al
skchow
Port stuffers
« Reply #3 on: 23 Mar 2004, 06:05 am »
What about using straws?  I remember that MBarnes suggested that awhile back for his speakers...
Sunny.
JoshK
Port stuffers
« Reply #4 on: 23 Mar 2004, 11:55 pm »
I just had a funny idea.  Any of you guys ever seen trumpet mutes?  Specificially the hard textured cardboard mutes? I use to be a trumpet player (6+ years) and had a few of these mutes.   I wonder how they would work as port stuffers.   I am sure it wouldn't be great, but it is just peculiar enough to work!
David Ellis
    • http://www.ellisaudio.com
Port stuffers
« Reply #5 on: 31 Mar 2004, 01:40 am »
I recommend Nike athletic socks.  Get the good ones made for tennis players.  They are thick and have a some Nylon in the weave.  Other cheap socks do an acceptable job initially, but the better socks are much more resilient.  They'll maintain a good seal inside the port for much longer.  Further, a quality speaker like the 1801s really deserves a high quality sock for port stuffing.  IMO, the Nike tennis socks are the best. :wink:
