0 Members and 1 Guest are viewing this topic. Read 24691 times.
How flexible are these? I'm considering them for my subs...
Mine is actually a 3 meter cable. Quite reasonable at $120. Probably wouldn't want to waste time shipping it or listing it for sale. I might eventually find a use for it. While it is sitting in a closet upstairs, I don't mind entertaining local offers of sale or trade. I agree that for my purposes if I had to order it again, I would have tried a long AC-14 for the bedroom system amp. I'm using a 14 ga. cable now. For most of my subs and source components which don't require heavy current draw I make my power cords with 16 ga. cable and I've had $500+ cords to try against it and preferred what I made. I have one of the big VH Audio DIY cords on my 20 amp Torus power conditioner and the cords I've made for my bigger amps consist of 16ga. doubled up or the equivalent of 14 ga. Both of my bigger amps (Bryston 14BSST and 6BSST) use 20 amp IECs even though they are 15 amp. So it was easier to make my own.
The Pangea if not used for your system can make a huge difference with the Plasma, LED or LCD. Sharper and better color. Give it a try. BTW that coiled AC cord is acting like an inductor adding resistance to the line. As far as duplex outlets a spec grade Hubbel 5262 or Jena duplex would be reccomended. Have fun. charles
They are fairly flexible but do not take a set per se so they need some space to wind around. There are much better cables out there Art but for a sub I would think they would do the trick.
For the 9awg size wire they are good. You will need a big bend radius as it is about 1.5" in diameter.Works well here with my Rythmik servo sub amps on the Super-V's.
