back light on cd-1 remote.
0 Members and 1 Guest are viewing this topic. Read 2032 times.
redbook
  • the music is the blood...........
« on: 17 Feb 2011, 12:27 am »
Hi .Could James or a fellow member tell me what the code is to activate the auto backlight on the remote. I have misplaced that one sheet on supplied info .Thanks  to anyone who knows   :duh: :duh: :duh:
  • The Demo is Everything!
    • http://www.bryston.com
Re: back light on cd-1 remote.
« Reply #1 on: 17 Feb 2011, 12:33 am »
http://bryston.com/pdfs/09/BR2_MANUAL_20090716.pdf
james
redbook
« Reply #2 on: 17 Feb 2011, 01:57 am »
Thank you ever soooooooo much James.you're an audio hero... :bowdown:
Napalm
« Reply #3 on: 17 Feb 2011, 02:52 am »
james
C'mon James, you should have let me suggest the crowbar first....
Nap.  :green:
srb
« Reply #4 on: 17 Feb 2011, 04:28 am »
Or simply going to the Technical Info page on the Bryston website.
rmurray
« Reply #5 on: 17 Feb 2011, 07:57 am »
Not everyone knows where to go with problems. It's nice of James to help out  in these cases. :wtf:
Vipers
« Reply #6 on: 17 Feb 2011, 02:44 pm »
This is an apt thread for me at the moment as I tried entering yesterday the code for the motion sensor to be turned on, but couldn't get it to work, I guess this is to activate the backlight when the remote is moved? As on my BR2 the only way to get the backlight to work is push one of the buttons.
Any ideas, do all BR2's have the motion sensor?
Thanks.
BrysTony
« Reply #7 on: 17 Feb 2011, 03:11 pm »
The motion sensor does not work if there is plenty of light in the room -- in other words it doesn't work if you don't need it.  Try it in a darkened room and it should work.
Tony
Vipers
« Reply #8 on: 17 Feb 2011, 04:14 pm »
Hi Tony,
Ah, that makes sense, I'll try it later, cheers  :thumb:
redbook
« Reply #9 on: 17 Feb 2011, 11:38 pm »
I wondered as well about same issue. Place your finger over that little lens thing near the top. The backlight should work because you've fooled the sensor eye.  ::thumb:
