AC receptacle cover
0 Members and 1 Guest are viewing this topic. Read 2154 times.
vett93
AC receptacle cover
« on: 14 Feb 2011, 05:48 am »
What do you use for the AC receptacle cover? I am thinking to use copper plates. But if you have better ideas, please let me know. Thanks.
srb
Re: AC receptacle cover
« Reply #1 on: 14 Feb 2011, 06:19 am »
« Reply #2 on: 14 Feb 2011, 01:34 pm »
Metal is more durable than nylon, but can allow for improper electrical connections.
srb
« Reply #3 on: 14 Feb 2011, 01:51 pm »
If you have money to burn and believe that an exotic cover plate will give you better sound than an indestructible nylon plate @ $0.44 (and there are people who do), or if it's worth a lot of money to you for a high-tech look, then you might want to consider
Carbon Fiber
Furutech 104-D (~ $85)
http://www.furutech.com/a2008/product2.asp?prodNo=251
Aluminum and Carbon Fiber
Oyaide WPC-Z (~ $225)
http://www.oyaide.com/e_audio/audio_products_files/wpc-z2.html
Oyaide says "The beautiful texture of carbon fiber and brightness of aluminum alloy project a strong presence as an integrated architecture" and cites vibration and resonance control as the primary performance enhancing feature.
jamesdb
« Reply #4 on: 15 Feb 2011, 02:43 am »
Here is a link to an extra heavy/thick, cast metal non-magnetic outlet cover that was used as an upgrade and available from Home Depot and other hardware stores.
http://www.audioasylum.com/audio/tweaks/messages/17/174577.html
rollo
  • Rollo Audio Consulting -
« Reply #5 on: 28 Feb 2011, 05:10 pm »
  Wood. Go to home depot and be done. Inexpensive and affective.
charles
