Audio Nirvana Will Release Tube Amps
0 Members and 1 Guest are viewing this topic. Read 4204 times.
« on: 13 Feb 2011, 04:05 am »
Hi,
Looking at the Audio Nirvana site, I saw they will release a integrated tube amp with two 6V6 output tube for 12Watts UltraLinear, price is under 1K dollars.
Looks good to me, assembly is point-to-point wiring, no PCB.
Gustavo
http://www.commonsenseaudio.com/nirvanaamps.html
> Never go to a psychiatrist, adopt a cat or dog from the street. On the streets pets live only two years average.
Guy 13
Re: Audio Nirvana Will Release Tube Amps
« Reply #1 on: 13 Feb 2011, 06:49 am »
Hi,
Gustavo
Hi Gustavo and all Audio Circle members.
It's not two 6V6 but four 6V6 two in parallel on each channel.
It's made in China for Common Sense Audio.
I think it will go for 995 USD, well that's uner 1,000 USD, no, yes, maybe ?
Guy 13
« Reply #2 on: 13 Feb 2011, 07:59 am »
Sorry Guy13, I mean say two 6V6 valves per channel for 12W.
Do you know how is the sound of these 6V6 tubes on power position??
I listen these tubes only in gain or drive position.
Gustavo
Guy 13
« Reply #3 on: 13 Feb 2011, 12:51 pm »
Gustavo
Sorry, I have no idea how the 6V6 tubes sounds.
Those tubes are often used in guitar amplifier,
which is not the same as audio amplifiers.
I am currently using 6L6 tubes in my SE-10 Niteshade Audio amplifier.
As you already know, different circuits around the same tubes can change their sound.
SE pentode, S.E.T, Ultralinear, push pull...
You can always write to David Dick at Common Sense Audio, but I am sure you will tell you the same thing as all the other manufacturers.
And that's: Their products are the best sounding and their electronic configuration is the best and bla, bla, bla...
Are they gona say that their products are no good?
Of course not, however, later on, they will say that they have improved their products, which more or less mean that their first generation of products were not that good from the start... (LOL)
Guy 13
« Reply #4 on: 16 Feb 2011, 02:31 am »
Guy 13
No so bad, seems this is the usual behavior with most of the manufacturers.
I already emailed Mr.David Dicks asking information and he was very friendly and do not hide informations about the fullranges.
Regards, Gustavo
