0 Members and 1 Guest are viewing this topic. Read 61788 times.
have you tried angling these in so their axes cross in front of the listeners' position?
If you really want to consdier a cool upgrade, replace your 8" visaton with a single point source coaxial driver, such as ones offered by eminence, p-audio, or B&C. I'm currently using an eminence CX2008 8" coaxial woofer with a Morel MDT-20 tweeter in the center. Its fairly effecient, around 92dB 1W/1M and the Visaton's high end simply cant keep up with the Morel. I went to this setup a year ago and never looked back!
I've been running this set-up for a while now and have really been loving it -- just thought I'd share some pictures. I would be interested in any feedback that you guys have.I am running these with my old Eico HF-81.I'm thinking i may try a H-frame on the two 15s in the next couple weeks.
Greetings!I just caught this and wanted to compliment you on your speakers. Very nice. I have a Fostex fe103e over one Alpha 15A in an H-Frame and I love it. Going with the H-Frame allowed me to shrink the size of the baffle enough that the overall footprint of mine is only 16"X17".I was wondering what type of material you made your baffle out of? Since you're talking about modifying, then with the round frames of all drivers in yours, have you considered flush mounting them? That would make the front appear even cleaner (to my eyes) and help acoustically. Also, have you considered U-Frames? That would keep the front nice and clean. Let us know how you proceed and what your results are!
hello,the Visaton is running full range with a phase plug installed. from there the two alphas are passive with a 2mH inductor. It is so simple that i never bothered with any software -- just tried a few different values and tuned to suit my test. The room and placement changes the character a lot; so i tend to stick with one value and move them around a bit to change the response.Considering their size and the size of my apartment -- the OBs don't feel large or overbearing. The relative 2-dimentionalness of them keeps them 'small' in the room. The music really is fantastic.
My first question is about time alignment: is there a basic rule/ formula for how far back the Visaton should be mounted relative to the Alpha? My current drawings have the Visaton about 1" back from the Alphas.
