Audio/Video Gear and Systems
The Lab
sts9fan
Overheated RCA connector soldering it.
0 Members and 1 Guest are viewing this topic. Read 1293 times.
nodiak
10 Feb 2011, 11:33 pm »
Wiring up a project (B1) and overheated an rca redoing a solder joint on the + part. So now it's loose, can spin it. I expect I shrank some plastic inside?
So should i replace it with a new one.
Fwiw I learned my solder lesson.
Sonny
Industry Participant
DIY-ing...
Re: Overheated RCA connector soldering it.
10 Feb 2011, 11:38 pm »
this happens...even to the best of them
don't worry, just buy a new connector...nothing is worse than a "loose" connector! You don't want to risk a "short"!
nodiak
Reply #2 on:
10 Feb 2011, 11:42 pm »
OK, have more. Will be more quickdraw mcgraw from now on.
Thanks, Sonny
Marvin Blando
Newbie
Reply #3 on:
23 Feb 2011, 01:55 pm »
I suppose it bears mention that when you solder an RCA connector, you should have a mating connector connected. It acts as a heat sink and stabilizes the terminal while you're heating and pushing it.
M
The Lab
sts9fan
