0 Members and 1 Guest are viewing this topic. Read 12958 times.
If you want Cheap and cheerful look at these. http://www.audioadvisor.com/prodinfo.asp?number=PGLS02These may be cheaper than cement blocks.
a stand with a large flat frontal area, like another speaker, will throw off the tonal balance ... essentially making the front baffle of the speaker much larger, and reducing baffle step losses
You guys realize that a stand with a large flat frontal area, like another speaker, will throw off the tonal balance ... don't you? By doing that you're essentially making the front baffle of the speaker much larger, and reducing baffle step losses, which will throw off the balance from about 500hz down.
Not to mention the extra resonance created by having the speaker coupled to another box.
Exactly why I was asking about granite slabs. Wouldn't they work pretty well?
Not to mention the extra resonance created by having the speaker coupled to another box. If you don't think this adds audible coloration, think again.Then, the entire situation is even made worse if there are still speakers in the cabinet being used as the stand.
