0 Members and 1 Guest are viewing this topic. Read 11427 times.
You would remove the power from the Firewire cable to isolate the data moving across the cable from the power moving across the cable. The wall wart on the Oyen can't have an adverse effect on the computer or the bits moving along the firewire cable in this case. So it's irrelevant. Likewise any effect of the power supply on the computer on the data moving across the firewire cable is eliminated because the cable is not carrying any power, just data.It sounds like the OP is looking for an alternative to something like the $250 "Most Beautiful Sound" firewire cable that both eliminates the power on the cable and uses a higher tolerance set of connectors and wiring.It would be an interesting experiment to see if just snipping the power connection in a run-of-the-mill firewire cable would yield an improvement vs. an expensive cable like the MBS.
..... power my HDD via bus power, not external noisy wallwart.
Bumping this in hopes of getting a better education.Ted,Isn't bus power also generated from a similar noisy power supply? I don't understand the difference.
In my case it's not theorizing; it made a big difference.
Ted when will we hear your comparison of the Young to the Weiss?
