0 Members and 1 Guest are viewing this topic. Read 11422 times.
I am looking for something in the lower price range than that. I have been looking at the unibrain cables. Would be nice to find a decent cable that I would not have to use an adaptor. I just want to know the pin config I should be looking for going from the Mini to the Oyen. Thanks.
Temple,Why are you not believing me? One more time: Get a 9 pin (MAC Mini) to 4 pin (so it has no power) like the one I linked...then a 4 female to 6 male adapter, so you plug it (6 pin male end) into your Oyen HDD's 6 pin port. Voila!
Well,,,,,,,,,, I dunno.As a refresher to this thread, I'm using a firewire 400 drive and I have discovered a noticeable improvement by switching to a GoldX firewire cable instead of the free firewire cable that came with the drive. I actually bought two GoldX firewire cables, one is the proper 6 pin to 6 pin cable and the other is a 6 to 4 pin cable with a 4 pin to 6 pin adapter. This configuration apparently removes the power leg. I've switched back and fourth a couple of times between the powered and non-powered GoldX cables and I can't hear a meaningful difference between the two. (Actually I can't hear any difference at all.)Maybe non-powered firewire is the best way to go, but in my humble computer audio set up I just don't hear a solid, musically compelling improvement using the non powered cable.Just my two pennies for now. Maybe some day I'll have a really good sounding computer audio source.
if you are removing the power from your firewire cable that attaches to your hard drive then where is the power (to power the drive) coming from?
I'm looking to experiment with using a FireWire cable with no power leg to connect my Mac mini to my external HD (where music files reside).
