Software For Audio Convertion
0 Members and 1 Guest are viewing this topic. Read 2373 times.
Osadu
« on: 15 Jan 2011, 07:42 pm »
Been thinking of getting into Bryston BDP-1.  What are the best softwares for converting CDs into FLAC, AIFF and WAVE files supported by the BDP-1.  Are they available commercially.
  • The Demo is Everything!
    • http://www.bryston.com
Re: Software For Audio Convertion
« Reply #1 on: 15 Jan 2011, 07:51 pm »
I use dbpoweramp - really good album art feature as well.
james
sfraser
« Reply #2 on: 15 Jan 2011, 07:52 pm »
EAC (exact audio conversion) which is free and or dbpoweramp at least for windows.
skunark
« Reply #3 on: 15 Jan 2011, 08:12 pm »
Sounds like you are new to this so, perhaps iTunes would be the easiest for you, just make sure you select the AIFF format (or Apple lossless) and turn on the error correction.   WAVE can be hit or miss for tag support (album art, artist, song titles, etc) so beginners might find it a bit frustrating to figure out the quirks.  If you want to do FLAC, then you need to look for something other than iTunes:
Here's a short list of cd rippers on Wikipedia: http://en.wikipedia.org/wiki/CD_ripper
Do keep in mind that most commercial apps will use open-source programs like cdparanara, lame, etc, so in the end almost all share the same guts, just a different facade.  Programs like Rip (sbooth.org) and Exact Audio Copy are great as they will also do a checksum online to give that one more level of confidence the rip was perfect and you can set them up to work with iTunes.
Ozi
  • If it don't weigh enough, it can't play enough
« Reply #4 on: 15 Jan 2011, 08:15 pm »
Dbpoweramp here also.
alexone
« Reply #5 on: 15 Jan 2011, 11:20 pm »
hi all!
what would be the correct resolution for vinyl recordings on hdd?
is it 44.1khz/16bit or are the higher resolutions the right choice??
thanks,
al.
Napalm
« Reply #6 on: 16 Jan 2011, 04:46 am »
hi all!
thanks,
al.
Without getting into any dispute about "how much information does vinyl hold".... I'd say 24/96kHz.... and this for the simple reason that in order to get an outstanding 16/44.1 you would need to have access to some pro gear and software to do filtering, noise shaping and so on.... 24/96 is much more forgiving so you won't need to do anything special...
Nap.
wilsonij
  • BDP1>SP3>7B3s> Vandersteen Quatros
« Reply #7 on: 16 Jan 2011, 10:13 am »
I'm a big fan of Exact Audio Copy: http://www.exactaudiocopy.de which produces very precise and repeatable results. You can use this to produce most kinds of lossless and lossy formats; my preference is FLAC but alot depends on how you intend to listen to the files.
Alongside that you'll need to keep an eye on the tags, which many systems use to interpret what you've ripped; I use mp3tag http://www.mp3tag.de/en/ which provides both individual and batch conversions of the data.
Finally there's the album art to consider; I've tried quite a few over the years and kept coming back to 'album art downloader' at http://sourceforge.net/projects/album-art/ for it's combination of versatility and active development.
Ian
alexone
« Reply #8 on: 16 Jan 2011, 06:54 pm »
ok. thanks guys! :thumb:
al.
alexone
« Reply #9 on: 18 Jan 2011, 04:27 pm »
Nap,
what do you think is the best software for vinyl recording?
al.
Napalm
« Reply #10 on: 18 Jan 2011, 05:22 pm »
Nap,
al.
I don't know which is "the best" as I didn't do any extensive testing, but this one is excellent value for the money:
http://www.sonycreativesoftware.com/audiostudio
and has an old vinyl restoration thing too:
http://www.sonycreativesoftware.com/audiostudio/effects
If you're also interested in video editing, you could go for this instead:
http://www.sonycreativesoftware.com/moviestudiopp
make sure you get the "Production Suite" version, and it will include Soundforge so you don't need to buy it separately.
Nap.
