Industry Circles
Bryston Limited
Interference from Transformers
0 Members and 1 Guest are viewing this topic. Read 1127 times.
klao
14 Jan 2011, 04:33 am »
Hi James,
Ideally, how far away should we place/setup other equipments (sources & preamp) from the power amplifiers and the TorusPower, in order to avoid interference, if any, from the big transformers within those amps/isolation units?
Thank you.
Facilitator
The Demo is Everything!
Re: Interference from Transformers
14 Jan 2011, 10:47 am »
Hi,
Yes they are very large transformers but given the Toroid design the magnetic field is very concentrated around the core and diminishes by the inverse square law. Think of it like a donut. So a reasonable distance I would say - depending on size - would be 6 inches to a foot.
james
Industry Circles
Bryston Limited
