In any event +- 2.5dB in the bass is going to be VERY difficult to achieve. I don't think your graph looks too bad.To bad to hear this from an professional acoustians. How was I been able to do it, I my self are not an proffesional. It's really to bad to hear this.There is visible room mode ringing at one frequency in particular - 25Hz? (you can see it in the time domain graph where the red / yellow tail is greatly extended in the time domain) that will be audible and you should try and deal with further. Unfortunately it is at such a low frequency that modifying your room construction or a tuned bass trap is going to be the only way to deal with it. Passive bass traps are not going to have any effect at that frequency.I agree on this one.If it is then you will need to use thick absorbers at the boundary that is causing the cancellation. Again it's going to require serious thickness to do the job due to the low frequency.Thick absorbers will not do it, sorry. Not in his roomRives should be able to fix this or else consult with a professional acoustician such as myself (my company is Acoustic Frontiers).Why should Rives Audio be able to fix it when they didn't fix it in the first place. Shame on Rives Audio.
