...I certainly would not worry unless you are definitely hearing (or not hearing ) a problem...Sit back and just enjoy the great music I am sure your system produces.
Looks like even Paul's EQed measurements weren't able to achieve that.
Did all you treatment items come from your level 1 purchase? I would call Rives and see what they had to say first.
will look into more bass panel ... I m concern it may absorb too much of the upper freq which is currently not as extended as I want.
Mike NomadA big +1 here. Given the length of your room, chasing something that is only a graph problem below 46 Hz. is a dicey proposition. If I'm looking at your graphs correctly, your LF dip is somewhere a little below that.Do you have any treatment(s) on the back wall ?why do u said that a 24.5ft length room cant go below 46hz? Would appreciate if you can elaborateBack wall is fillted with LP racks and there is 2 2x4 ft absorption panel near each side of the corner trap
