0 Members and 1 Guest are viewing this topic. Read 12505 times.
Sub-dividing from another thread comes the new question to ponder. perhaps you have had some experiences with different cartridges and alignments, good and bad. Things to consider: The arm itself, anti-skating, and stylus type (conical, elliptical, shibata (fine-line)).There are also a whole bunch of alignments out there, some I have never hear of before. The usual ones are Stevenson, Bearwald (Lofgren A), Lofgren B and Heywood, many others.What makes you pick a particular alignment?Wayner
Never thought of picking an alignment.I just use a DB Systems protractor and fly with it.Always have on Rega arms BTW.What else should I try?D
It comes out right on. This is an RB 700 on my P5, but I used the DB Pro on all my RB 300's I have had in the past. It pretty much matches the Stevenson position too.I'll take a look at that Lofgren B Wayner suggested.I do not hear inner groove or outer groove distortions.D
I mounted my Rega RB300 at 220 and had just enough slot room to do the Lofgren B. I wish I had moved it 1 more mm in, to 219. Oh well.Wayner
Ok how's this one? For something different.I had this printed with the info but had not tried it till this evening.http://www.vacuumstate.com/index.tpl?rubrik=4&lang=2&a=%25BB%2540%25AE%25B3%258ES%2590%2589&b=734496.1317766324Rowan McCombe's (aka The Guru) Phono Cartridge ProtractorI have been using this alignment for the last 4 hours. Extremely good!!! Musical and balanced.Why does this one work so well? I had it tweaked in 30 minutes.Try it.D
Actually the Guru has null points that are very different from Baerwald or anything else for that matter. I haven't heard it and I don't intend to as its distortion numbers are off the charts as indicated here:http://www.audioasylum.com/audio/vinyl/messages/69/691903.htmlNull points are addressed here:http://www.audioasylum.com/audio/vinyl/messages/69/692071.htmlMight be an irrational fear but I would be a bit afraid of damaging my records with that alignment.
