0 Members and 1 Guest are viewing this topic. Read 12209 times.
Marc,Good point. Although geometry doesn't change regardless of stylus shape, distortion might, and tracking ability certainly will. I guess it could be argued either way regarding distortion. Because the stylus has a thinner side profile and is able to resolve more information, tracking error becomes more noticeable? Or, because tracking ability is improved with greater vertical groove contact and thinner side profile, there is less minor mistracking and loss of information. Or, all of the above.When I tried a micro line stylus with Stevenson, on an arm of 240mm eff length, it sounded great, even spectacular, on all but the beginning of record. There it was good, but not great. I think arm length is the key here. I wouldn't use Stevenson with arms of less than that eff length. With 9" arms, you're better off with Baerwald or Loefgren. IMO Baerwald is better with those arms. I had a couple of different ones with that geometry (Linn) and Baerwald seemed best. They were the Zeta and Alphason 100S, which I still have. YMMV
Yes, I agree the tracking error does not change due to profile. That is simple geometry. The Stvenson Nulls though I believe came about to "cure IGD" due to stylus profile moreso than geometry. Tying this into the other threads about carts and alignment choices. Still not trying to hi-jackl this.......you still up for a "bicycle" with the MCZ and the Alphason?Marc
One point protractors like Geodisc, Dennesen, and Clearaudio are based on the actual location of the pivot (not where it theoretically should be) and will give excellent results if used properly.
Re Stevenson: Yes, no doubt about it - not arm geometry, more like groove geometry. One thing to consider; If you look at Wayner's distortion/tracking error graphs, those numbers or curves are computed for an arm of a given eff length. Increase the length of the arm and the numbers decrease. This was discussed before in Alternate Alignment thread. An interesting aspect of this came from your fav speaker company, Magnapan. Before they came out with their tonearm, Unitrac, they spent a lot of time trying to sort out the optimal compromise between lower tracking distortion with a long arm and increased mass with worse moment of inertia. They settled on 240mm or about 9.5" as optimal. Even before I heard of the Unitrac, I noticed a big difference in distortion on arms with greater eff length. One thing though, this is a low mass arm, designed for high compliance carts. I don't know how much that influenced their decision.It seems to me that there is a rather dramatic difference as length increases between 9" and 9.5", although I have no problem listening to a 9" arm. HW of VPI thinks 10.5" is optimal, or so I'm told. Regarding your generous offer to audition the MCZ - believe it or not my Sonus arm is still not repaired. Matter of fact now it even needs to have the ground wire soldered inside the pillar. It's one thing after another with that arm. I had the lifter platform off, to fabricate another and I lost the damn thing. I was using it w/o cueing when it started humming like crazy. When that arm is working (w/custom headshell) it sounds spectacular with higher compliance carts. I figured a 6g damped unipivot would be ideal. The Unitrac is 7g, but undamped. 2 other arms I have are too heavy. Is an 11g Alphason appropriate? Davey's Ittock is around 13g if that's what he's using for Grados. Maybe we can sort it out via PM or email. That TLZ I tried had maybe the sweetest vocals I ever heard on a stereo. neo
Not all protractors will work for all turntables with tonearm pre-mounted. Geodisc will not work on Pro-ject 6.1, it's tonearm was mounted based on other curve that the Geodisc was made for. The best thing to do is to use the protractor that came with the turntable.
Is the MCZ body a low or med out? It doesn't really matter. If I use the AHT I can set the gain or resistance for just about anything. But it would be a good idea to give me a ballpark. I might have to order some resistors. I could also get some other values to make plugs for a conventional MM stage and compare results. Even if the output is around 1mV, it will work with the Revelation 2. That pre has 20dB of gain in the line stage which is usually too much. I'll email you.neo
