0 Members and 1 Guest are viewing this topic. Read 12198 times.
That's why Wayner maxed out the cartridge's forward adjustment on his headshell. Either Technics mounted the arm wrong, or Wayner screwed up his paper tool. When he finalize his paper tool, he may have to file the slots longer on his headshell to get his overhang right, then the null point will be way off on the protractor. His paper tool is based on the assumption that all the tonearms are mounted wrong on the turntable, so that he has to "check" with his paper tool, and it's still wrong, because the overhang is incorrect.
Here we have a perfect example of an unknown pivot/stylus distance. This renders a 3 point approach useless. Many arms are mounted with pivot/stylus distance altered a mm or 2, sometimes intentionally. I wouldn't rely on a guesstimate of this distance to set my alignment. "I'm not abandoning the 2 point method, it is the essential last step in the alignment process." Yes, it is the last step to check accuracy. Why? Because you say you've had imprecise results using a 2 point alone, doesn't mean it can't be achieved. Obviously you're doing something wrong. If you need an intermediate step to get there, so be it. If the 2 point is the final check, then it follows that getting the 2 point correctly will yield exact alignment. "I have installed and aligned many cartridges using the two point system, and when I brought it over to the overhang scale, it was off, no matter how hard I tried, back and forth and back and forth." This makes no sense. What happened when you changed it for correct overhang, it no longer was aligned on the 2 point grids?FYI, the arc of the stylus (overhang) is contained in the grids of a 2 point. It is an abstract that intersects the targets of each grid. Get the stylus/cantilever to line up, both in distance and angle on both grids and you are using the arc to align. I'm not opposed to using other means to get tangency or other nulls, for that matter. But I object to your statements about protractors being inaccurate, just because you've had problems. You still haven't addressed the problems with arms located at unknown distance or fixed headshells. I guess it's easy enough to have overhang arcs on a template. But if mounting distance is unknown, it's useless. neo
Here is the distortion plots for the Technics Lofgren B alignment.Neo, you are absolutely correct about the Technics and it's way old Stevenson alignment. Grado users may benefit from the inner null point, tho. Wayner
I'm not sure I understand that point. My nulls are set at 66mm inner, and 120.9 outer. I've run just about any configuration from FTE+1 to the Sonata1.Linn arm(s) mounted at 210.7 (not the advertised 211) and stylus at 229.
That would be a very large WRONG. My Technics is set into a Lofgren B alignment. At the standard 215mm spindle to pivot spacing, which my little ruler proves, the overhang for a Lofgren B is 18.282mm. That puts the cartridge at the end of the slot, but it is in the correct position and the table sounds awesome. The Technics, and it's shipped alignment tool will set the cartridge into a Stevenson alignment. That is 215 pivot to spindle distance with a 15mm overhang. That would set the cartridge back about 3.282mm from where it is now, or about in the center of the slot. With the Technics, you can actually set it to the Lofgren A (Bearwald), Lofgren B, Stevenson or even a Heybrook alignment.
My bad, you are referring to my Grado comment. I think Grados are wonderful cartridges. I make the Grado Gold1 and Green1 Longhorns for Audio by Van Alstine. On some particular tables I have found that the Grado really picks up inner track distortions after inside of the first null point, between there and the label. Using the Stevenson alignment solves that problem. I have no explanation for this, as it only seems to occur with one other table that I have.Which makes me want to ask the next question. Are some cartridges just plain better suited for some alignments?Wayner
Marc, one more comment on the Grado then back to the topic. I think the problem is really caused from anti-skating settings. I have a Sony PS-X7 as well, also a PS-X5, but those are not "the other table" I had a problem with. It was in fact my old Empire, which I know has an anti-skating issue, because of it's age and it was a spring loaded device, not magnetic as so many others are.Wayner
Slight correction - Stevenson nulls = 60.325 and 117.42Baerwald (Loefgren A) = 66 and 120.89Loefgren (B) = 70.29 and 116.6Stevenson reasoned that because distortion is greatest at the inner grooves, it beneficial having the inner null near where the record ends. This alignment can sound really good with longer arms. Inner groove distortion isn't greater because of arm geometry. It's greater because of the smaller groove circles.Baerwald and Loefgren are pretty close sonically, even though the numbers look very different. You'll notice that Loefgren nulls are closer to the center of record. That's where tracking distortion is greatest, and that is why Loefgren has lowest total distortion. Baerwald has a more even amount of error throughout the record. neo
One point protractors like Geodisc, Dennesen, and Clearaudio are based on the actual location of the pivot (not where it theoretically should be) and will give excellent results if used properly. That is the key. If I'm using a 2 point, I have pin holes to make sure I have the right distance, and magnification and proper lighting to see if lines coincide or square up. I normally align the cantilever with the anti-skate off. I also use a flashlight to make sure the angle of the light isn't causing an error. You shine the light at different angles - you'll see what I mean.
