LCY ribbon tweeters beyond 20kHz
0 Members and 1 Guest are viewing this topic. Read 2555 times.
DaveMBE
« on: 21 Dec 2010, 03:11 pm »
Hi guys,
Not sure whether this is the correct section to ask this technical question. (redirect me if I am wrong please)
LCY spec their dual ribbon tweeters to 60kHz and even 100kHz yet only provide frequency response plots up to 20k
Has anyone swept/used these tweeters beyond 20kHz to see if LCY's claims are true?
I am developing a LF to 50kHz soundsystem for a scientific project and need flat response to super-sonic frequencies.
All links, suggestions and help greatly appreciated.
Thanks in anticipation
Dave
Rick Craig
  • Selah Audio
    • http://www.selahaudio.com
Re: LCY ribbon tweeters beyond 20kHz
« Reply #1 on: 21 Dec 2010, 03:18 pm »
Forget the LCY and use a RAAL 70-10D. I've not tested it beyond 20K but it should work fine for your purpose. It's a  better design than the LCY (plus LCY has had quality control problems).
JohnR
« Reply #2 on: 22 Dec 2010, 09:34 am »
Interesting question. I can't help wondering if there are ultrasonic transducers designed specifically for that purpose.
pelliott321
« Reply #3 on: 22 Dec 2010, 01:51 pm »
*Scotty*
« Reply #4 on: 22 Dec 2010, 08:54 pm »
DaveMBE
« Reply #5 on: 26 Dec 2010, 02:31 pm »
Hi everyone,
Scotty's recommendations look a lot less 'bumpy' than the RAAL's too, so as long as they don't plunge off the cliff above 40kHz I could have found what I am looking for.
Thanks for your thoughts and kindness in taking the time to reply.
Happy New year to you all
Dave
Jed
    • Clearwave Loudspeaker Design
« Reply #6 on: 26 Dec 2010, 03:12 pm »
+1 about the LCY110 driver consistency issues.  Although IIRC, the issue was around 6khz (a large hump in response not in manufacturer plots), so as a super tweeter it might be okay.  I haven't tested all the LCY tweeters.
