0 Members and 1 Guest are viewing this topic. Read 28639 times.
This assumes that you have a pretty decent amp to begin with.
Any opinions on the Morrison E.L.A.D. preamp? That's what I have now and it seems pretty good. Absolutely silent and neutral, but I have not used many other preamps to have comparisons. Hence, I'm considering a change.
Not to derail,but what is your source?
In terms of absolutes you can get by without a pre-amp (if you don't do vinyl, have only a single source, and don't use tone controls or subwoofers), so I'd say the power amp is more important (unless you only use headphones). Several CDPs and DACs include volume controls. Then there are the in-line attenuators for the purists (that's what I use).It really depends where you are on the audio quality scale and how well all your components synergize. Like wilsynet stated, passive (or no pre-amp - the ultimate passive) can sound very good but all the stars must be in alignment.
I have owned many preamps:In the past 30 years:Hafler DH110 I built from kit with phono. Very nice, loved it, BUT traded it in for:Sony (first digital processor pre) ??ES1000 , suckered by bells and whistles.. chunk of trash.. biggest mistake of my audio life.. Got rid of it to buy:Used Counterpoint 2000 which i dearly loved and it broke several times so sold it after relegating it to doorstop status: (wish I had kept it!!! and had it fixed properly)New Adcom 750, the 'audiophile one (with a blue board, mine was actually green board early, early production, but what the H.) Kept that for a long time. ThenFound a cheap used Audio Research SP-10.. was OK, but tried another used SP-15 and liked it MUCH better, so sold the SP-10.. thenBought a Bryston BP-26 last Spring.Then tried a cheap tube buffer, OK with DAC, so i splurged for a used VAC Standard to use just as a tube buffer (glorified, but still just a buffer)SO: currently I am using the Bryston, with the BP 1.5 phono. and using the Audio Research SP-15 just as a second (tubed) phono, into the Bryston BP-26, and the VAC Standard as a tube buffer between the DAC and Bryston.For amps I have had Carver, Forte' 4a and now Bryston 4B-SST2.So having tried more preamps than amps, I would say a preamp has more effect on sound quality than an amp (in general) thought this DOES NOT APPLY if comparing tubes amps with SS ones.I am sticking to this story.The Hafler was musical, as my first 'real audiophile' preamp. the Sony was NOT musical. I stopped listening to music, but took a long time to realize why!!!The Counterpoint was musical, but broke a lot, I loved the Counterpoint.The Adcom was good. reliable.The SP-10 was OK, needed great tubes to shine, Mine had cheap, crummy tubes. and had a lot of 'tube noise' so it never really had a chance to shine, and I was not about to spend a $1,000 for superlative tubes. The Sp-15 is nice, better than the Adcom. But the Bryston BP-26 is better than the SP-15Notice I started leaving out 'musical' Well I think it takes tubes to have that musical sound, not accurate, but pleasing.The VAC is not as clean as the SP-15, which is exactly what I want in a tube buffer, to 'hide' the digital HF crap. without diminishing the music.I would go for a 40th Ann. Audio Research if I had buckets of money, or a top of the line Conrad Johnson. Or even the Ref 5 ARC.. Tube preamp heaven.I bought the Bryston to last me the rest of my life... (I just retired.)I would also say a preamp 'adds' to the sound, where an amp only subtracts from the sound if it is not so good.IMO.Also I like clarity more than any other quality in my stereo. So the Bryston gives me that the best I have found in a midpriced preamp.If I HAD $12 to $20K to blow, I would be looking at the tube preamps i mentioned.
The amp / speaker combination is the most important except for the speaker / room combination. I live happily without the distortion of a preamp. But they add convenience and people like the sonic colors they bring. I don't like the colors. The amp colors it enough already but is necessary.
