WTB: Decent but Affordable Stands
0 Members and 1 Guest are viewing this topic. Read 1478 times.
Mass. Wine Guy
« on: 19 Dec 2010, 02:44 pm »
I have a pair of Silverline Minuet bookshelf speakers ad want stands for them. Something around 30 or 36 inches high. By affordable, I'm thinking up to $200 or so.
Thank you.
timind
  • permanent vacation
Re: WTB: Decent but Affordable Stands
« Reply #1 on: 19 Dec 2010, 03:15 pm »
I used a pair of Sanus Steel Foundation stands with Silverline Audio SR-11s. Nice stands for the money.
http://www.audioadvisor.com/prodinfo.asp?number=SASF%20%20%20%20%20%2026BLK
eclein
« Reply #2 on: 19 Dec 2010, 03:52 pm »
If you want something thats flexible as far as future purchases and changing height check out:
http://www.sweetwater.com/store/detail/MonitorStd
I have some and although they are pretty utilitarian they work well and can adjust
I found some here on AC as every once in awhile someone sells some but either way the brand I got is excellent-"Atlantis"
Audio Advisor has a bunch of brands:
http://home-audio.audioadvisor.com/search?p=Q&lbc=audioadvisor&uid=487305334&ts=custom&w=Stands&af=cat1:speakerstands&isort=score&method=and&view=list
Parts Express:
http://www.parts-express.com/wizards/searchResults.cfm?srchExt=CAT&srchCat=515
bushbison
« Reply #4 on: 19 Dec 2010, 05:08 pm »
+1 for the Sanus stands... more attention to detail than most stands in this price range (comes with cork "buffers" -??- to eliminate rattling etc.), especially if you load the stands.
jonbee
« Reply #5 on: 19 Dec 2010, 05:22 pm »
VTI model DF stands are very good for ~$100 shipped. Very solid, with a cast iron base, heavy tube and are fillable. A great buy.
http://www.racksandstands.com/VTI-DF-VI1045.html
To get better you need multi-pillar stands with a much wider footprint for greater stability.
I'm not sure those are available for under $300.
Mass. Wine Guy
« Reply #6 on: 19 Dec 2010, 05:33 pm »
Wow! Thank you. I will look into all of these suggestions.
themailman
« Reply #7 on: 20 Dec 2010, 04:54 am »
i have a pair 24in solid steel stands i will let go for $225.00
