Salvaging a Pair of Mini Tower IIa Speakers...
0 Members and 1 Guest are viewing this topic. Read 1391 times.
DuDro
« on: 17 Dec 2010, 07:50 pm »
I have a pair of Mini Tower IIa speakers that have been stored in the closet since 2003.  All the rubber/foam surrounds appear to be fine, but the cabinets are bit damaged.
The cabinets were originally damaged in a move, along with the grills.  I had set aside for a "repair/restoration" project, but never got around to them.
They have been "rediscovered" recently as I am preparing for another move, so I have been tinkering with the idea of harvesting the speakers and crossovers for a custom project.  :?
My initial design ideas are leaning towards something slim, like the RM30s.  My questions are as follows:
1) Should I abandon this and just attempt to repair the existing cabinets and grills?
2) If I harvest the speakers, where can I find specs for them so that I can design a proper cabinet?
3)  If I harvest the speakers, is there a easy-to-use program that I can use to aid in the cabinet design?
The extent of damage includes crushed corner on the cabinet, broken binding posts, cracked bases, and broken grills.  :cry:
Any constructive feedback would be greatly appreciated!  :D
Brian Cheney
    • http://www.vmpsaudio.com
Re: Salvaging a Pair of Mini Tower IIa Speakers...
« Reply #1 on: 19 Dec 2010, 12:08 am »
If you want to build a new cabinet, just measure the outer dimensions of the MTII's and subtract 1 1/2" from each dimension to get the internal volume, which you can duplicate within 10% when making a new cabinet.
Sounds like the damage to the old boxes is considerable and not worth repairing.
