Question About an Amp Chassis
0 Members and 1 Guest are viewing this topic. Read 2557 times.
Mass. Wine Guy
« on: 14 Dec 2010, 11:19 pm »
I just bought a used ClassD Audio amp that was installed into a jtwrace chassis. The left channel input and output are on the right side of the chassis (looking from the amp front) and the right is on the left side. Does this seem odd to anyone else? Jason, a man of few words, told me that not all systems are laid out in the traditional left is left/right is right manner.
« Last Edit: 15 Dec 2010, 01:03 am by ServerAdmin »
srb
Re: Question About an Amp Chassis
« Reply #1 on: 14 Dec 2010, 11:29 pm »
Very odd.
JohnR
« Reply #2 on: 14 Dec 2010, 11:44 pm »
How is it if you look from the back?
srb
« Reply #3 on: 15 Dec 2010, 12:04 am »
Please show me another amplifier that has inputs and speaker outputs that are on opposite sides of the back panel that are reversed, causing cables to cross to get to where they need to go.
raindance
« Reply #4 on: 15 Dec 2010, 12:08 am »
What does it matter? Using the right channel as left or the left channel as right makes NO difference. Stereo is 2 channels. As long as you get the right info to the correct speaker, who gives a rats? Nothing needs to cross.
srb
« Reply #5 on: 15 Dec 2010, 12:17 am »
Actually I do.  It's a silkscreen legend layout error.
TrungT
« Reply #6 on: 15 Dec 2010, 12:34 am »
McIntosh MC2200  :scratch:
poseidonsvoice
    • 2 channel/7 channel setup
« Reply #7 on: 15 Dec 2010, 12:36 am »
So does the rear of your chassis look like this?
or is it like this:
Anand.
Mass. Wine Guy
« Reply #8 on: 15 Dec 2010, 01:33 am »
It's truly not a big deal with me. I just thought it was unusual. Poseidon, the top photo is what my amp looks like.
So what if I cross the lines? I don't want to have to keep thinking how left is really right, etc.
srb
« Reply #9 on: 15 Dec 2010, 01:48 am »
There is no problem in crossing lines.  I was just agreeing with you that it is indeed odd (and illogical).
poseidonsvoice
« Reply #10 on: 15 Dec 2010, 01:48 am »
It's like what you said. No-Big-Deal. Cross them, you'll be fine, try to avoid your power cord if you can.
Anand.
