Acoustic treatment
0 Members and 1 Guest are viewing this topic. Read 2609 times.
Anonamemouse
  • +52° 03' 30", +4° 32' 45"
Acoustic treatment
« on: 12 Dec 2010, 01:39 pm »
Just buying the amp and CD player doesn't cut it. One also needs some acoustic treatment (as long as the WAF is respected of course).
Here is the nekkid truth about acoustic treatment. Keep the wife at some distance...
john1970
Re: Acoustic treatment
« Reply #1 on: 12 Dec 2010, 02:33 pm »
Definitely the naked truth on acoustic treatment!!  Also, a good idea to keep the girlfriend away as well...   :green:
Napalm
« Reply #2 on: 12 Dec 2010, 02:51 pm »
You basterds. Please put some kind of warning on material that's not suitable to be viewed in the office.
Nap.  :finger:
Phil A
« Reply #3 on: 12 Dec 2010, 02:58 pm »
I always tell people the room is the most overlooked component.  I treated the main system (and measured it with my RTA) and I have used an SPL meter with test tones for the bedroom system and I trying hard not to drag the RTA into the bedroom or basement secondary systems to avoid the onset of my audiophelia which flares up from time to time 8)
Anonamemouse
« Reply #4 on: 12 Dec 2010, 04:36 pm »
Nap.  :finger:
:D I kinda doubt that the gesture you make is suitable for the office as well...
Stephen L
« Reply #5 on: 12 Dec 2010, 05:22 pm »
I want to definitely take care of those peaks and valleys  :drool:
redbook
  • the music is the blood...........
« Reply #6 on: 12 Dec 2010, 09:48 pm »
O.K. Now I have to go out for awhile .My amp is overheated and there's a short in my wire system..... :eyebrows:
Napalm
« Reply #7 on: 13 Dec 2010, 04:11 am »
If your room has really poor acoustics, may I suggest headphones instead of acoustic treatments?
Nap.  :green:
1oldguy
« Reply #8 on: 14 Dec 2010, 03:48 am »
Good lord..I want one or make that two of those for the 25th. :thumb:
