DEQX
0 Members and 1 Guest are viewing this topic. Read 4300 times.
versus rider
DEQX
« on: 9 Dec 2010, 01:49 pm »
feel free to move this if necessary, but I mostly frequent this circle. Anyone have experience of any of the DEQX models. I have recently bought the PDC 2.6 and it has transformed my system of open baffle bass and compression driven horns.
« Last Edit: 9 Dec 2010, 03:28 pm by versus rider »
Rick Craig
  • Selah Audio
    • http://www.selahaudio.com
Re: DEQX
« Reply #1 on: 9 Dec 2010, 02:19 pm »
feel free to move this if necessary, but I mostly frequent this circle. Anyone have experience of any of the DEQX models. I have recently bought the PDC 2.6 and it has transformed my system of open baffle bass and compression drivem horns.
A DSP system like the DEQX is the best way to go with an open baffle or dipole speaker.
versus rider
Re: DEQX
« Reply #2 on: 9 Dec 2010, 03:29 pm »
who else has one was what I meant to put in the op. :duh:
D OB G
Re: DEQX
« Reply #3 on: 10 Dec 2010, 12:39 am »
Hi versus rider.
I have the HDP 3.
Can I be of any help?
David
(I too use open baffle and compression driver with waveguide- now the Parts Express 6" X 6" elliptical and a BMS 4450nd).
JohnR
Re: DEQX
« Reply #4 on: 13 Dec 2010, 09:18 pm »
I think Nyal Mellor said he was using one.
Nyal Mellor
  • Founder - Acoustic Frontiers.
    • Acoustic Frontiers
Re: DEQX
« Reply #5 on: 13 Dec 2010, 09:40 pm »
I have one but not used it in anger yet
JohnR
Re: DEQX
« Reply #6 on: 13 Dec 2010, 09:57 pm »
Oh. Did you get your driver selection sorted?
versus rider
Re: DEQX
« Reply #7 on: 14 Dec 2010, 05:28 pm »
Hi David, maybe if I get stuck but so far I have muddled through. It takes a little time to get used to the software, i.e. understanding there are three configurations that can have three different crossover/filter settings or even different speakers asigned to them. I have managed to measure the drivers, set the crossover points, choose filters and take room measurements. Then adjust the eq graph, so far its doing a superb job.
Hi versus rider.
I have the HDP 3.
David
D OB G
Re: DEQX
« Reply #8 on: 15 Dec 2010, 11:10 pm »
Hi versus rider.
I've sent you a message.
David
Nyal Mellor
Re: DEQX
« Reply #9 on: 21 Dec 2010, 05:56 pm »
Well I got to the point where I learnt that maybe an MTM wasn't the best idea, so my current plan is AE Dipole 15", a 6.5" hi-efficiency pro mid such as a PHL. I got stuck on tweeter selection, specifically a AMT seems like a good choice from the fact that it is naturally a dipole however I am worried about the difference in power response at the XO between the AMT and the 6.5" mid. Maybe I'll go to back to back mounted dome tweeters...unless any one has any sage advice...
JohnR
Re: DEQX
« Reply #10 on: 22 Dec 2010, 12:04 pm »
Perhaps the Neo10's that studiotech is using might be part of a solution (from the other way, so to speak).
