Titanium Software? (freeware)
0 Members and 1 Guest are viewing this topic. Read 1861 times.
jtwrace
    • TIPP YouTube Channel
« on: 6 Dec 2010, 02:15 am »
Has anyone used it?  If so, which one and what were the results?
http://www.titanium.free.fr/index.php
« Last Edit: 6 Dec 2010, 12:47 pm by jtwrace »
avta
Re: Titianium Software? (freeware)
« Reply #1 on: 6 Dec 2010, 03:59 am »
I've used Onyx for years and like it very much.
planet10
  • Frugal-phile (tm)
    • planet10-hifi
« Reply #2 on: 6 Dec 2010, 04:38 am »
Onyx is non-optional software in my books.
dave
Phil A
« Reply #3 on: 6 Dec 2010, 04:59 am »
Thanks for the link.  I might give it a try
skunark
« Reply #4 on: 6 Dec 2010, 07:46 am »
This seems totally optional and mostly pointless.   A lot of the features you can already do.
jtwrace
« Reply #5 on: 6 Dec 2010, 12:46 pm »
How about explaining why?
orthobiz
Re: Titanium Software? (freeware)
« Reply #6 on: 6 Dec 2010, 01:28 pm »
The only really problematic maintaining-type software I've encountered are those, like Spring Cleaning, that remove duplicate files, etc.
My go-to program is DiskWarrior.
I have used Onyx before but never really knew if it did anything. Guess that means it's seamless and good!
Paul
skunark
« Reply #7 on: 7 Dec 2010, 09:21 am »
The "maintenance" application features:
 repair permissions,                          <-- Disk Utility, first aid, click on repair
 run periodic scripts,                         <-- guessing if one knows how to write scripts, then they can edit the crontab
 reset Spotlight’s Index,                     <-- rare, but google for command line
 rebuild the LaunchServices database,  <-- rare, but google for command line
 delete Application,                           <-- drag to trash can or if available use uninstall script (advanced apps will have this)
 Font and System cache,                    <-- rare, but google for command line
 check the status of the Hard disk...     <-- Disk Utility
I didn't mean to sound "harsh" I just have a gamer's mentality, i.e. don't install applications you don't need and don't be afraid of the command line.
HumanMedia
« Reply #8 on: 7 Dec 2010, 12:46 pm »
You would have to be a geek without a life to Google for terminal strings or trawl through "man" for even 10% of what Onyx provides simply with a nice GUI for free.
And let's not forget the massive room for errors when using "rm" to simply clean your caches via the command line. If you are even wondering what the features of Onyx are, the last place you should know about is the command line.
A thumbs up to Onyx, a great free utility.
skunark
« Reply #9 on: 9 Dec 2010, 09:09 am »
command line is simple, i would rather google that then install some unknown software that could contain a keylogger.  But of course I do understand what rm -rf /* means.   if you don't then I would still assume this isn't the app for you.
