Are all fuse holders in IEC jacks the same?
0 Members and 1 Guest are viewing this topic. Read 2279 times.
Gopher
« on: 4 Dec 2010, 10:48 pm »
I recently blew the fuse in the IEC jack of an amp.  I popped out the fuse assembly to bring with me to homedepot to replace the fuse, but lost it somewhere between my house and my car.
I am not a DIY guy and don't want to replace the whole jack--are the plastic fuse holder assemblys standardized?  I know the amp is working fine and behaving normally--the fuse was a fluke and I don't want it to impair my listening.
UPDATE:  I found it!  Back in business, just waiting on my 845Bs to arrive now
« Last Edit: 5 Dec 2010, 03:11 pm by Gopher »
Wayner
Re: Are all fuse holders in IEC jacks the same?
« Reply #1 on: 4 Dec 2010, 10:59 pm »
The max amperage fuse on most IEC inlets is 10 amps, but yours may be different. Your device should have an amperage rating for the fuse on the back panel. I suggest you replace it with the same type and rating (amperage and speed (fast blow, slow blow)).
Wayner
srb
« Reply #2 on: 4 Dec 2010, 11:02 pm »
I think what Gopher is saying is he just didn't lose the fuse, but the holder assembly that fits into the IEC assembly as well.
satfrat
« Reply #3 on: 4 Dec 2010, 11:09 pm »
Maybe you could email the amp company and ask them to send you a replacement?
Wayne1
« Reply #4 on: 4 Dec 2010, 11:24 pm »
You don't seem to be having much luck with amps lately  :roll:
In taking a quick look through both Mouser and Digi-key catalogs, I do not see the fuse holders listed separately from the power entry modules. I think Robin's idea is the best. Try to get a replacement from the manufacturer. If that won't work, measure the entry module (IEC inlet) and try to find one that is close in either Mouser or Digi-key. You will then have to replace it.
Gopher
« Reply #5 on: 4 Dec 2010, 11:37 pm »
Yep,  the plastic assembly is the issue.  I'll give the dealer a ring tomorrow and see if he has one.  The amp is a Shuguang, so...  yeah not really an easy call to to manufacturer.
Wayne,
On the topic of fuses, I've got the one in place in my dac and will be dropping you a line shortly.
jtwrace
    • TIPP YouTube Channel
« Reply #6 on: 5 Dec 2010, 01:31 am »
What are you doing with the S-30?
Gopher
« Reply #7 on: 5 Dec 2010, 01:37 am »
That was sent out to Atma-sphere yesterday.  A couple resisters went and I'd rather them take a look at it, do a couple updates/modernizations and get her acting optimally rather than just bringing it to a tech to replace the resisters.
The IEC with the missing fuse receiver is from a different amp, an 845 monoblock I picked up at a good price and wanted to compare to the healthy Atma-sphere to pick a winner in my system.  Both amps are liquid so I was hoping to compare and pick a winner before it came time to pay the credit card bill (refuse to keep a balance) but if little things keep going wrong this may not be an option.
Gopher
« Reply #8 on: 5 Dec 2010, 03:12 pm »
I found 'em.  Thanks guys.
