how to open duet squeezebox receiver
0 Members and 1 Guest are viewing this topic. Read 5026 times.
etcarroll
« on: 1 Dec 2010, 03:37 am »
Bought one from ebay, it worked a month, then died. Just got a new one.
I'd like to pop open the old one to see if it can be brought online.
How is the best way to open one of these?
Wayne1
Re: how to open duet squeezebox receiver
« Reply #1 on: 1 Dec 2010, 04:01 am »
There are four screws on the bottom of the Receiver under the pad. You will have to peel the pad back at the corners. You will need a torx T-10 driver to fit the screw heads.
If you have problems with it, you can send it to me and I will be willing to let you know if I find any problems with it. I do have a bit of experience with those units.
etcarroll
« Reply #2 on: 1 Dec 2010, 04:07 am »
Thanks, the symptoms are;
- no light on front led,
- low, constant high pitched whine.
Gene
Wayne1
« Reply #3 on: 3 Dec 2010, 05:10 pm »
Gene,
As a first step, you might want to try removing the wireless card. There have been a few failures with this card.
etcarroll
« Reply #4 on: 3 Dec 2010, 05:27 pm »
Thanks!  :thumb:
holland141
« Reply #5 on: 17 May 2012, 05:15 pm »
Hi Wayne
I have a duet that is also a bit dead. I cannot factory reset it - it stays on the red slow light and will not be seen by the controller, or indeed my router
Before I open it up - do you know another way to 're-boot'. The logitech support has not been that great - they keep sending me to FAQ that I have read
Thanks in advance
