New BP16 hum
0 Members and 1 Guest are viewing this topic. Read 1442 times.
RonCH
New BP16 hum
« on: 5 Nov 2010, 05:21 pm »
Hello,
I just bought a new BP16 and when I plugged it in to mains power I noticed that it makes a humming noise.  It's the amplifier itself that noisy.  It sounds like a power supply noise.  It's not loud but you can definitely hear it. Is this normal, or is my new amplifier faulty?
Ron
  • The Demo is Everything!
    • http://www.bryston.com
Re: New BP16 hum
« Reply #1 on: 5 Nov 2010, 05:27 pm »
Hi Ron,
Mechanical hum - should not be.  Try a different plug as well.
james
RonCH
Re: New BP16 hum
« Reply #2 on: 5 Nov 2010, 05:38 pm »
Hi Ron,
james
I swapped around power leads and it's made no difference :(
Re: New BP16 hum
« Reply #3 on: 5 Nov 2010, 05:43 pm »
Hi Ron,
No I meant try it in a different power plug to make sure it is not that particular outlet.
If it's a mechaical hum it should not be - what is the serial number and from whom did you purchase it?
james
RonCH
Re: New BP16 hum
« Reply #4 on: 5 Nov 2010, 05:57 pm »
Hi Ron,
james
OK, I tried another power outlet and it makes the same noise.
BP16-000120 and I bought it from Hifi Zurmühle (Hirschmattstrasse 34 CH-6003 Luzern Switzerland).
I must say though the BDA-1 -> BP16 -> 2x7BSST -> PMC PB1i does sound fantastic.
Ron
« Last Edit: 11 Nov 2010, 05:22 pm by RonCH »
