K&K Audio Class A Differential Linestage
0 Members and 1 Guest are viewing this topic. Read 1912 times.
jtwrace
    • TIPP YouTube Channel
« on: 28 Oct 2010, 11:21 pm »
Has anyone here built and completed one?  What are your thoughts on it?  What have you compared it too?
http://www.kandkaudio.com/linestage.html
jtwrace
Re: K&K Audio Class A Differential Linestage
« Reply #1 on: 29 Oct 2010, 06:42 pm »
I'm shocked!
JoshK
« Reply #2 on: 29 Oct 2010, 08:10 pm »
Looks like a great design, but I haven't built it.   I've heard good things about it though.
nicksgem10s
« Reply #3 on: 29 Oct 2010, 10:21 pm »
I have had mine for about a month and absolutely love it.  I did not build it but acquired it from a gentleman that is very skilled and talented with electronics.
I thought it would be excellent and it has exceeded my expectations.
I am using it with my Hagerman Cymbal 8 watt monoblock tube amps.  It is an incredible combination.
I believe there are others on AC that are building or that have built it.
This is a very serious preamplifier.  If I compared it to commercial equipment I have owned it would be in some pretty expensive company.
I give it my highest recommendation.   :thumb:
-Nick
poseidonsvoice
    • 2 channel/7 channel setup
« Reply #4 on: 29 Oct 2010, 11:42 pm »
-Nick
I've got the kit, just haven't built it yet. But I don't doubt at all its sonic splendor as Kevin Carter is an ace designer. As a diy'er I'm only too lucky to know him. The 6N6P tube he uses has very similar sonic characteristics and lower spectral harmonic distortion spectra than 6SN7's if that means anything. Definitely something I would like to compare with the Atmasphere MP-3 or Allen Wright's RTP-3 designs. If you want balanced differential they are all nice options to audition.
Good luck in your search,
Anand.
jtwrace
« Reply #5 on: 29 Oct 2010, 11:43 pm »
Anand.
I look forward to you getting yours done.  I'm sure you do too.   :thumb:
