0 Members and 1 Guest are viewing this topic. Read 17805 times.
I am reading of at least two mod approaches to improving Maggie sound clarity. John at Magnestand favors using hardwood frames to dissipate the vibrations of the mylar drivers into the frames. This idea allows the driver to recover quickly. Others have made frames that decouple the tweeter from the bass driver, and others have mentioned a more massive frame, such as Corian in place of the stock MDF, which would keep all the energy within the mylar driver. Which idea gives better results?
Great stuff men. I tell ya your perking my interest again in my 3As. Pipedreams have replaced them when I got into SETs. Charles
Anyways, has anyone consulted with Magnepan for an ultimate material and or frame/enclosure ? Just curious if they would help or recco anything as an alternative. Do they do anything different for the 20.1s ?
Don't forget you will need completely different amplification for IIIas. Even on the ribbons, I doubt that a SET will do.Magnepan have not shown themselves to be interested in spending the time to respond to "interesting" questions like that. As far as I'm aware (from seeing some pics someone posted after a factory visit), the 20.1 frame is MDF like all the others. And they kept all the drivers in the one frame.Regards,Andy
I've heard the stock 20.1's a couple of times in big rooms with big power and loved them both times. One can only wonder how good they would sound with a "Gunned" frame/bracing setup or similar mod. It would take some serious courage to just start ripping apart speakers that cost that much money to begin with.
Anyways, has anyone consulted with Magnepan for an ultimate material and or frame/enclosure ? Just curious if they would help or recco anything as an alternative. Do they do anything different for the 20.1s ? charles
... That would likely mean aluminum, followed by Baltic birch ply...
I used Kreg pocket screws. It was a piece of cake The difficult part was cutting the slot for the ribbon and all the routing for the rabbits for the panel and ribbon. It just took time, I practiced on poplar. My mantra was that this was my last speaker and I wanted it to look as good as it sounded.I simplified things a lot by not using a base.
I can't believe placing the crossover boxes on the floor or on the speaker base is going to make any audible difference. Cheers,Dave.
