A favor from James Tanner
0 Members and 2 Guests are viewing this topic. Read 1547 times.
mkaiser
« on: 19 Oct 2010, 06:18 pm »
Hi James,
I was wondering if you could get in touch with Mike Pickett about wheather the front faceplate of my BCD can be changed to the newer radiused faceplates. I emailed him over a week ago and have not gotten a relpy back. I have to take the BCD in for servicing of it's LED display and figure i may as well get the faceplate changed while it is at Bryston.
Mark
  • The Demo is Everything!
    • http://www.bryston.com
Re: A favor from James Tanner
« Reply #1 on: 19 Oct 2010, 07:22 pm »
Hi Mark,
I am back at Bryston tomorrow from the show so will do.
james
« Reply #2 on: 19 Oct 2010, 07:32 pm »
Hi Mark,
I checked and I assume your in Germany?  Mike tells me the faceplate can not be changed by the consumer as it is not an easy task so you would have to contact Sun Audio our distributor.
james
mkaiser
« Reply #3 on: 19 Oct 2010, 07:55 pm »
Hi James,
Thanks for the quick reply. Actually i live in Canada in the K-W area. Would i take it into my certified Bryston dealer Natural Sound in Kitchener and have them send it in to Bryston?
Thanks again,
Mark
« Reply #4 on: 19 Oct 2010, 08:46 pm »
If that's easier for you  - otherwise just send it to Bryston direct.
james
1oldguy
« Reply #5 on: 21 Oct 2010, 01:00 pm »
Im interested in this as well James,Could you tell me the cost for the new BCD faceplate?
