Candela question
0 Members and 1 Guest are viewing this topic. Read 3222 times.
Charles Xavier
Candela question
« on: 19 Oct 2010, 12:06 am »
I have been told that the Candela inverts phase. Can anyone tell me this for sure ? I have searched and can't find any info on this
golfugh
  • Dead Can Dance - Into the Labyrinth
Re: Candela question
« Reply #1 on: 19 Oct 2010, 12:16 am »
Charles yes it does, I had one.  Great pre!
Charles Xavier
« Reply #2 on: 19 Oct 2010, 12:35 am »
So I have to reverse my + and - on my speakers ,right ?
aaron.luebke
« Reply #3 on: 19 Oct 2010, 01:22 am »
I got mine this year and talked to Klaus about that - he said on some systems it's a night and day change when you switch + and -.  On others no noticeable change.
It's worth a try.  My system didn't care.
AlexG
« Reply #4 on: 20 Oct 2010, 12:17 am »
Charles,
Yes, the Candela preamp does invert phase by circuit design. The best way to do it is to just invert the cables at the speakers terminal.
Alex
Eduardo AAVM
« Reply #5 on: 22 Oct 2010, 05:34 am »
Hi Alex, some of our mexican friends would like to know what is the idea behind this desing principle, I know you did it since the begining but I think you could share again with us.
Thank you
AlexG
« Reply #6 on: 24 Oct 2010, 02:01 pm »
Eduardo,
The Candela circuit topology is based on a classic mu-follower (constant current) using twin triodes. Without getting to technical, this circuit allows for the output signal to be taken from the upper plate (non-inversion) but with a higher output impedance, or the upper cathode (phase-inversion) with a much lower output impedance. I decided to go with a lower impedance.
Alex
Eduardo AAVM
« Reply #7 on: 28 Oct 2010, 06:22 pm »
Thanks Alex !
