Has Anyone Used An Archos 7 To Control Your Headless Music Server?
0 Members and 1 Guest are viewing this topic. Read 2779 times.
ebag4
I just ordered and Archos 7 to control my mpd music server.  Does anyone have any experience with this unit?
Ed
Alexdad54
Ed,
How has that gone for you? I'm trying to figure out a solution as to how to have a remote control for my W7 netbook that runs my Foobar/external HDD combo feeding a DAC. The Archos 7 looks very interesting....
chadh
I was thinking one of the wi-fi equipped e-book readers, running android, would work well.  I might ask for one for Christmas.
Chad
ebag4
I received the Archos and within a day decided to return it.  The touch screen is not in the same league with the Apple solution and the WiFi reception was poor.  I liked the size but that was about it.  I decided to pick up an iPod Touch and use mPod.  Although I had reservations about being able to pick items on the smaller screen I found that I adapted very quickly.  The touch with mPod is head and shoulders better than the Android solution IMHO.
Best,
Ed
Alexdad54
Thanks for the info Ed, much appreciated.
From what I could see on the website, mPOD is a player is it not? I guess that would then preclude using Foobar?
ebag4
I seem to be having a problem getting this response to post, lets try again:
mPod is a remote client for MPD (music player daemon).  I am currently running MPD on a silent fanless linux based computer as described in nyc-paramedic's thread seen here ( link removed because it was preventing me from posting).  BTW, I am running FLAC files.
Best,
Ed
giannettino
Hello..
i'm using an internet tablet Archos 5 with foobar and http server plugin..Works quite fine in my setup..and, btw, you can choose your skin.. :thumb:
Ciao!!
Alexdad54
Hi gianettino,
Can you provide details re the http plug-in you're using? Just curious.... :scratch:
Alexdad54
Grazie tanto! :thumb:
