Bp 26/dac module V Bda 1
0 Members and 1 Guest are viewing this topic. Read 2324 times.
mauvedipstick15
« on: 9 Oct 2010, 07:03 pm »
Anyone know what the difference is apart from the extra inputs on the Bda 1 and power supply maybe.Is the performance noticably different between the two.
Ozi
  • If it don't weigh enough, it can't play enough
Re: Bp 26/dac module V Bda 1
« Reply #1 on: 9 Oct 2010, 07:11 pm »
Hi,
good question, I am curious too only regarding the sound quality.
Thank you for asking and thanks in advance for incoming replies.
Best,
Oz
Phil A
« Reply #2 on: 9 Oct 2010, 07:46 pm »
Ozi
« Reply #3 on: 9 Oct 2010, 08:07 pm »
mauvedipstick15
« Reply #4 on: 10 Oct 2010, 09:17 am »
Thankyou.
Phil A
« Reply #5 on: 10 Oct 2010, 11:38 am »
You're both welcome.  James' post is what made me think of getting the DAC.  Didn't think I'd use so many inputs but I was wrong.
Armaegis
« Reply #6 on: 5 May 2016, 03:15 am »
I didn't want to start a new topic so I thought I'd bump this old one:
Has the optional dac module for the preamps/integrated amps changed much over the years? If I have one from 15 years ago, is there any point in considering updating it if it has changed? I don't have any need for high-res, and while I'd certainly consider the standalone dacs I'm trying to simplify my current systems and reduce the number of components I have. (I know it's a dirty lie, but I gotta make that effort every once in a while)
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #7 on: 5 May 2016, 09:05 am »
HI
No they have not changed much other than a move to surface mount circuits over hole through and some layout changes.
james
