0 Members and 1 Guest are viewing this topic. Read 17820 times.
Based on that new testing data, I'm also going to implement 200Hz notch filter on the subwoofer. That hump is probably effecting output even with the crossover at 100Hz. You can see the output is NOT down 24db at 200hz like it should be.
Your way of EQing a dipole is not the usual one afaik. You start with a 12 dB/oct shelving filter at 96 Hz. Obviously this is much too weak. Most others would start with the crossover low pass at 30-50 Hz and second or even third order. You first want to get the response flat from the lowest target frequency up to the dipole peak region. This way all peaks higher up get much more attenuated than with your method. The shelving filter would only be a second thought if you want to cross over lower than at the natural roll off of the H frame into the first dipole dip.The filters of the DCX do work as good as they should and they do have enough cut/gain. But they have to be used with a good strategy: Start with the more powerful filter and adjust with the less powerful one - not vice versa.
I'm really curious about the alignment you selected for the two mid woofers, the dome midrange and the tweeter. It looks to me like the acoustic centers form a perfect arc, but maybe that just worked out as such. Did you calculate their relative distance based on frequencies? Just curious. When I experimented with offsets in my current configuration, the measurements showed only a small difference off-axis. With my previous config, (not coax) it was larger.
Can you spell out that strategy in more detail for me? I would be happy to improve the setup. To clarify, in my understanding with my existing setup I get full output at bottom end, reducing to -15db at 96Hz with 12db/octave HP EQ ... and I apply LR 24db/octave crossover above 110Hz.
After mounting everything and getting the system up and running I looked at the time delayed alignment of acoustic centers:I measured the distance of the cone to a point in space near listening position to confirm that the time alignment settings for each driver were set as accurately as possible. Also delayed ALL the smaller drivers by almost 6ms to match the delayed impulse response time of the big 10" drivers. The time alignment had a much bigger effect on the sound than I ever imagined it might.
After doing so, the delay came out to 23ms and I halved that time as an approximation since the higher frequencies would also essentially follow the same path, but at a faster speed. I wound up with 12ms and my listening position is about 10 ft in front of the speakers.
Above strategy of yours is the green curve - starting with the (light green) 15 dB shelf filter and moving over to the (dark green) cross over filter. The dark green line is including the part of the light green filter above 110 Hz:
I recommend another strategy: Start with a 12 dB/oct lowpass crossover at 30 Hz (or wherever you find appropriate). This would move everything along the lilac line to the level of the dark lilac line - compensating the dipole rolloff very well. After that you could apply the brown shelf filter at 310 Hz to subdue any remaining ondulations above 200 Hz up to another 15 dB.
I think my comments may have been misleading because I think you are not thinking properly about how to use the delay. The delay should not be set to the time required for sound to reach your ears. Also the sound from the tweeter does not travel substantially faster than the sound from the woofer.
The top end of my green curve (the 12db/octave -15db cut) ENDS at 96hz instead of 150Hz. So in my estimation, it would start at about 40hz wouldn't it?
... but I always thought it would be preferable to use 24db/octave at required crossover frequency.
I thought that 96 Hz was your input number for the DCX EQ. If it is the end of the shelf, both filters would merge at the right point, and your strategy would follow what SL shows in http://www.linkwitzlab.com/proto.htm#PW1. This would be valid of cause, but it would not allow to move the cross over to higher frequencies.
Hmm, I've always used some delay to offset the higher frequencies, to prevent them from arriving at the listening position too early. This is done in pro-audio applications all the time, granted the distances traveled are typically greater
This is done in pro-audio applications all the time, granted the distances traveled are typically greater. .
It is also one of the advantages of biamping
But many common dipole configs include a small, wide range driver and a rather large (15-18") helper woofer with largish Qts
my experiments with time delay in this case have not been as beneficial, perhaps addressing some lesser phase anomolies, as opposed to a real need to compensate for the slowness of some larger drivers.
Within my 4 way: - I delay the 6.5" drivers by 6.16ms to match the delayed response of the 10" peerless XLS drivers - I delay the 2" driver by an additional 36mm over the 6.5" to match the acoustic centerline - I delay the 1" driver by an additional 26mm over the 6.5" to match the acoustic centerline
Im just curious and would like to compare notes with you as far as your physical setup goes. Can you describe how the two dipoles are situated in your room and where your typical listening position is located.
Without your seperate sub active, can you describe the roll-off as you walk across the room from one side to the other.
From http://www.musicanddesign.com/Dipole-offset.html: "In conclusion it is apparent that the conventional wisdom of correcting AC offsets using allpass delays or other means of introducing excess phase in the crossover, as applied to box type direct radiator speakers, is flawed when applied to speaker systems employing multiple dipole sources. This is because the offset of source 1 relative to source 2 reverses as we move from the front side of the dipole speaker to the rear side. If the offset is X cm from the front, it is -X cm from the rear. Thus the delay compensation, while the same magnitude, would have to be applied to the 2nd source rather than the 1st, or vice versa, situations which can not exist simultaneously. Application of a delay will alway introduce greater error to the rear response if it corrects the misalignment relative to the front of the speaker. The only correct solution is to physical align the AC of the two dipole sources."
