0 Members and 1 Guest are viewing this topic. Read 23674 times.
I enjoy both, and I try not to trump one over the other. I think that folks that grew up with vinyl are not as shy or intimidated as others such as newbies may be. I've heard some damn fine CDs that brought every bit of the emotion to the performance, but the same can be said for a well cared for vinyl collection, played on a properly set up and tuned TT.Wayner
Its also interesting to note that in16 bit recording not all bits are used for music. I think its only like 12. So 12 x 6 =72 db of dynamic range... hehe. Maybe 13 at 13x6 =78db of dynamic musical range....right in line with your analogue output dynamice range..
I am not sure where the myth is here ? But Cd revolves around getting 2 volts of bit rate. +1 and -1 volt. which is a pure analogue reference. with every bit of cd we can expect 6 db of dynamic range thereabouts. Its a pure digital artifact
werd I'm going to have to call you on a couple of things.First, can you clarify this statementSecond, This statement needs a citation from an outside source rather than your (...I think it's only like 12....) I think I interpret your first statement to mean that by -72dB only 4bits are available to describe the analogue waveform.Wayner the CD medium does not have a usable 100dB dynamic range, as the recorded waveform moves away from 0dB towards -100dB there are fewer bits available to describe the waveform which results in a rising distortion level as you move towards -100dB. (See my guess at the meaning of werd's first statement.) By the time you hit -70 dB you have about 3% THD.When analogue recordings were done on tape the commonly accepted maximum THD was reached when you exceeded 0 dB by the amount necessary to produce 3% THD on peaks. Here is a picture of the 16 bit recording medium undithered sinewave at exactly –90.31dBS,from Stereophiles measurements of the DAC Magicas an example of how bad the distortion is.This is why the actual dynamic ranges available from vinyl and CD are similar. This is also why I want to see a wider availability 24/96 recordings of popular music,ie recordings of music I am actually interested in listening to as opposed to music that Holt's law can be applied to.Scotty
What effects, if any, does dithering have on distortion?
Hi ktDithering has big effect on distortion or jitter really. Dithering is making sure there is no trailing voltage hanging around. They adjust it by looking at 0 voltage output. If its anything other than 0 that means there is more voltage present while signal is being decoded. Where does this excess voltage end up? In digital the voltage is extremely regulated so any excess ends up making devices heat up more than they are tolerated to, especially in dac chips, this is will destroy a dac chip eventually and make for bad sound along the way.
werd,when you rip a copy of a CD onto your hard drive as a 16 bit wave-file where do the extra bits come from if they were not on the CD to begin with? Like wise,when a DAC locks onto an incoming data stream and identifies it as 16bit in nature is it lying and calling a 12 bit data stream 16 bit?Scotty
Here's the best quantitative evidence that I've found on the net, regarding why vinyl sounds more live than a 16/44.1 CD.But, in the end, not even vinyl can replace a live show...-Clayton
It was a bit hard to trace where that graph came from. Here's the link:http://www.6moons.com/audioreviews/feickert3/blackbird_3.htmlHere's an excerpt:"We found a graph at Merging Technologies that tells more than the proverbial thousand words. In this graph MT compares the impulse response of analogue playback to various forms of digital playback and shows that only full DSD can compare to analogue. It is this lightning-fast ‘unclipped’ impulse response that makes analogue sound much more ‘live’ than digital."
the source does not specify but I assume it's probably voltage?though still not measuring near analog or DSD the newest evolution in apodizing filters goes a long way in eliminating pre and post ringing seen with more conventional filter designs I still flinch at the claim that vinyl is "superior" because the freq response extends well past 20khz as I haven't heard many dog whistles in my life and therefore fail to appreciate how such info and superduper tweeters can benefit playback unless it involves some subconcious stimulation or whatever???
