0 Members and 1 Guest are viewing this topic. Read 4751 times.
"Keeping the wand short reduces resonances within the arm which typically colours the music. It is probably one of the major influences contributing to the overall sound of a tonearm. Manufacturers of conventional pivoted arms go to great lengths to try to eliminate resonances. They have a hard job!Together with a lightweight slider, Terminator has the lowest lateral inertia of ANY airbearing tonearm on the market weighing in at just over 80g including the saddle, counterweight & cartridge, allowing safe tracking of the fussiest high compliant cartridge."
I am ordering a Soundsmith Voice. I currently use a 20cu Grado with no issues, 10hz vertical resonance, on an MG1 airbearing. Peter advised against the 28cu model which confuses me because Trans-Fi owners are use 32cu carts with what seems to be much more lateral mass. Should the horizontal effective mass be high in order to use high compliance? I have calculated that the tad heavier SS cart and higher compliance will actually drop down my vertical resonance to maybe 8 (and the I used the calculator to estimate 10hz and test records bore this out as accurate). The effective lateral mass of the MG1 is stated at about 28g.
