Confused about compliance matching with airbearing
0 Members and 1 Guest are viewing this topic. Read 4752 times.
doctorcilantro
Re: Confused about compliance matching with airbearing
« Reply #20 on: 27 Sep 2010, 03:51 am »
It is a problem? Yes, the tonearm mass should "low", theoretically. How much is too much? I haven't even looked into what kinds of lateral effective mass if offered from many popular fixed-point tonearms. Is it 10? 20? 30g?
I thought the Shure ultra had 30cu, guess I was wrong. Maybe it's the V15? The AT33PTG is noted at 40 static I think, but 10? dynamic?
What happens on a large lateral modulation with a stiff low compliance cart. and medium/heavy mass in the arm? The same cart on a low mass arm? Doesn't a more compliant cart. allow for a great movement of the cart. body in response to such modulations, and not break?
Some of these carts are amazingly heavy:
Benz LP S-Class Specifications
Output: .36mV
Stylus: 5x120µm
Impedance: 38 ohms
Loading range: >400 ohms
Weight: 16g
Compliance: 15cu
Tracking force: 1.8-2g
Koetsu Coralstone Platinum Cartridge Specifications
Body: Coralstone
Type: Moving coil
Coil wiring: Silverplated copper
Magnet: Platinum magnet
Stylus type: Proprietary
Cantilever: High strength boron
Output volts: 0.3 mV
Frequency response: 20-100,000 Hz
Channel balance at 1 kHz: Better than 0.5 dB
Channel separation at 1 kHz: Better than 25 dB
Inner impedance: 5 Ohm
Recommeded impedance: 30 Ohm
Weight: 12.5 g
Compliance: 5 x 10-6 cm/dyne at 100 Hz
Neobop, I'll be the first to admit you guys know more than I; just throwing this out there in the spirit of learning.
thanks
dc
