Power Cables That Work Well on Stratos Ex. Monos
0 Members and 1 Guest are viewing this topic. Read 4302 times.
petern
« on: 17 Sep 2010, 03:55 am »
I understand it's a controversial topic but just want to narrow down my search and experiments. Please share what have worked well, or not, with your Stratos Extreme Monos, preferably something that don't require a second mortgage to finance  :wink: For references, please also state the brands and models you used prior to discovering your favorite. Thanks - Peter
germay0653
Re: Power Cables That Work Well on Stratos Ex. Monos
« Reply #1 on: 17 Sep 2010, 01:41 pm »
I've use the following with Khartago SE+++ mono extremes.  Relatively inexpensive, high quality (All UP-OCC Copper) and easy to build.
Neotech NEP-3002 11 awg with shield AC Power Cable
Neotech NCP-M011 Male plug
Neotech NCP-IEC001 IEC plug
petern
« Reply #2 on: 18 Sep 2010, 03:24 pm »
I love OCC wires, I am using TDK OCC speaker wires at the moment and loving it!
How are the wires attached to the connectors, crimping or soldering? If it's crimping, is the tool readily available at local electronics part stores? I've never done this and am very interested. It looks like VH Audio carries the wires for DIY.
petern
« Reply #3 on: 18 Sep 2010, 03:28 pm »
germay0653
« Reply #4 on: 18 Sep 2010, 09:09 pm »
You can pick up the bulk cable and connectors at several on-line stores (see below).  No need to solder or crimp.  The Male plug and IEC plugs all have slots that the wire goes into and a metal clamp screws down on the cable.  All you need is a phillips head screw driver.  Instructions come with the connectors.  Good luck!!
On-line stores:
VH Audio - carries the bulk cable and other manufactures plugs
Sonic Craft - carries the bulk cable and the connectors
Parts ConneXion - carries the bulk cable and connectors
Take Five Audio - carries the bulk cable and connectors
stereo5
  • Current System
« Reply #5 on: 18 Sep 2010, 11:08 pm »
I think you asked this question on the Asylum.  I use a Shunyata Copperhead power cord on my Stratos stereo Extreme amp.  My entire system is wired with Shunyata power cords and conditioners.  Here's a thought:  Why not call Klaus and have him make you a cord out of the high end Groneberg cable he sells?  Your amps are wired with it and would surely benefit from it.  If I wasn't so heaavily invested in the Shunyata, thats what I would do.
Bob
petern
« Reply #6 on: 19 Sep 2010, 03:48 pm »
Thanks Stereo5. I'll look into that.
Eric
« Reply #7 on: 20 Sep 2010, 05:29 pm »
This is probably very subjective. Works well typicall means produces a sound I like. What sound are you looking for and what do you expect the pc's to accomplish for you other than getting power to the amps?
Randy
« Reply #8 on: 20 Sep 2010, 07:10 pm »
http://signalcable.com/magicpower.html
Excellent and inexpensive cables I used with great success with my Mono Extremes.
Nicholas Bedworth
  • That's me, the one with the glasses...
    • DigitalDirect Website and demo
« Reply #9 on: 10 Oct 2010, 01:23 am »
Also try the Clairvoyant Liquid Air  power cables from www.audio-magic.com. They're the best so far for my Kismet-in-Stratos cases.
