0 Members and 1 Guest are viewing this topic. Read 5302 times.
So how does that work, just the left in/out on one, and right in/out on other?
Thank you. Grant Fidelity has a P-307 that I'm very interested in. Cheers Charlie
It doesn' look like it will do MC but I could be wrong it's been known to happen
Got an MM cartridge. MC cartridges open up a can of worms. Best if I stay away from them. K.I.S.S. is my motto. Cheers Charlie
Hey Bro!!! You get what you pay for!! Many,many,many Phono pre's out there that cost 'MUCHO" bucks. $325.00 I consider on the inexpensive side. I spent a little time at Grant Fidelity's room at the Cal. Audio show. For the cost of his gear you're getting a lot of bang for the buck. I'll probably go ahead and order one. Stay tuned for the results!! Cheers Charlie
So let me see if I'm getting it(call me DumDum). If I bought the P-307 and somewhere down the road I bought an MC cartridge it's probable that I'd need a step up transformer. Right? Cheers Charlie AKA DumDum
Yup, just like that. Then, hook up a regulated 12v power supply to each of them in place of wall wart. It need not be expensive - $73.50 for another TC-760LC and used, regulated 12v (linear) power supplies a-plenty on ebay typically under $30 each. Old Radio Shack units tend to be the norm. Like this: http://cgi.ebay.com/Radio-Shack-12v-Regulated-Power-Supply-120VAC-12V-DC-/140452412957?pt=LH_DefaultDomain_0&hash=item20b39dbe1dYou need to buy two of the same exact kind (a little harder to do).So, for maybe $125 more (or, $200 total invested in all), you should have a very, very decent phono stage to use. True dual mono, right back to regulated power supplies, is simply a great thing for better vinyl playback Goodbye weak imaging and limp bass John
