VMPS speakers with Bryston amplification
0 Members and 1 Guest are viewing this topic. Read 1028 times.
G E
« on: 14 Sep 2010, 01:40 pm »
Hello,  I have the vmps rm30m speakers and am considering a bryston power amp to drive them, either the 4bsst2 or 7bsst2 lines
preamp is belcanto pre6 anolog multichannel
Has anyone here a similar set up?
Thanks in advance for your comments and observations
GE
cliffy
Re: VMPS speakers with Bryston amplification
« Reply #1 on: 14 Sep 2010, 05:41 pm »
You might also get some responses on the VMPS circle here on AudioCircle.
I would suggest posting your question there as well.
I know of at least one Bryston dealer that is very active on that circle.
Best of luck.
John Casler
« Reply #2 on: 14 Sep 2010, 06:01 pm »
Best of luck.
Hi Cliffy and GE,
Yes that is me.  I am a VMPS dealer and a BRYSTON dealer and have many VMPS clients who love the sonic results of the relationship.
The VMPS speakers will certainly reflect the quality of the electrons you feed them and if you like accuracy and purity, the BRYSTON is surely one of the best choices to place in the drive chain.
My standards are always "low noise", accuracy, high amperage/power, and ability to respond to and resolve micro and macro dynamics.
BRYSTON provides this and your RM30's will do the rest.  As well, as long as you choose a model with moxy (4bSST or above) you will have the BASS the speakers are capable of.  Leading edge attack and impact with 300wpc will be quite exciting.  As well the RM30 is a 4 ohm load so you actual power limits will be more like 500wpc.
And stability is an important quality and the BRYSTON amps provide that in spades.  The 7bSST will simply take that level and ease of dynamic transition even higher.
The BRYSTON amps (IMO) are among one of the best choices for your RM30's.
