Cheap 'tweek' for better video
0 Members and 1 Guest are viewing this topic. Read 1951 times.
TheChairGuy
« on: 12 Sep 2010, 06:33 pm »
Ferrite cores 8)
Yup - I had a couple around from experiments with audio/rca cables. They stripped some measure of artifacts from the line, but left the music less natural sounding.  So, that cheap experiment went back in the audiophool toolbin for a couple years.
I haven't been that blown over by my new (Best Buy) 46" Insignia TV LCD/LED picture...even on HD channels from Comcast. Also, there is notable lag between video and audio when folks are talking...and I read that this goes away by changing out HDMI cable between box and TV.
I use the (free) HDMI cable that came with the box.
I was thinking of 'upgrading' the cable in hopes of getting a better picture and improving that video/audio lag...when I looked over at monoprice.com for cables.  I noticed all their 28awg cables came with built in ferrite cores...and they sell them as accessories on the 24 and 22awg cables, too.
Well, out came the ferrite cores from the failed audio experiments of a few years ago and VIOLA! - noticably better picture was the result (confirmed by my wife - who isn't unwittingly fooled by supposed tweeks as easily as I am :wink:)
The audio/video lag is still there, however, it's fairly dramatically reduced to barely problematic now.  I'm not much of a videophile, so I may not even get a new cable to see if this could be banished entirely.....I'm pretty happy to put long lingering projects to better use with my video  :wink:
I cannot comment on audio quality, as mentioned I did not like for sound what these ferrite cores did for my audio-only system a few years ago - the audio portion of my video system is not sufficient resolution to hear anything unnatural about them.  So, they'll be staying in the video system for perpetuity now :thumb:
At Radio Shack for whopping price of USD$2.99
For very small gauge...http://www.radioshack.com/product/index.jsp?productId=3012599
For larger gauge.....http://www.radioshack.com/product/index.jsp?productId=2103222
John
Charles Xavier
Re: Cheap 'tweek' for better video
« Reply #1 on: 12 Sep 2010, 08:10 pm »
These came with my Samsung Plasma
coke
gooberdude
« Reply #3 on: 25 Jan 2011, 12:48 am »
As a follow up to a great suggestion, lately i've been tinkering with Highwire Power Wraps on ac cords.
To date, I havent had any luck with them on interconnects or speaker cable, but they are amazing on ac cords and HDMI cables (the ic version).
My 42" Panasonic plasma tv has an iec power cord with a big ferrite ring on it, close to the tv. As an experiment i installed a power wrap & experienced better video.  I took it a bit further and removed the ferrite ring from the tv, re-tuned the power wrap, and an even better picture & audio are the result.
i cant knock ferrite's, I have 10 AudioQuest ones somewhere if anyone wants them.  IMO the power wraps are a better a/v solution. they never strip or bleach the signal it seems like.
Surprisingly, oem installed ferrite rings can be easily crushed with pliers. They just sort of crumble under enough pressure.
matt
BobM
« Reply #4 on: 25 Jan 2011, 05:25 pm »
Now go build yourself a Felix power conditioner (but use the heavier capacity choke) and put that on your power strip feeding your TV and cable box and DVD player. You will certainly see an even more dramatic improvement in your picture.
