Help with usb input on my wyred 4 sound DAC
0 Members and 1 Guest are viewing this topic. Read 1078 times.
rgcards
« on: 7 Sep 2010, 01:48 am »
This morning I tried to set up my Wyred 4 sound DAC2.  I have an HPlaptop running windows vista home(32 bit) and I tried to use Foobar 2000 playing FLAC files.  The output from FOOBAR 2000 was set to W4S spdif, and the dac read USB  44.1 .  Itried using 8,16,24,and 32 bits output without a sound ecer coming out of the speakers.  Any help anyone?  I am new at this so even the stupidist of mistakes is more than possible.  Thanks
             Ravi
Vincent Kars
  • The Well Tempered Computer
Re: Help with usb input on my wyred 4 sound DAC
« Reply #1 on: 7 Sep 2010, 10:00 am »
If you connect the DAC using USB then Foobar must be set to use USB too.
SPDIF is digital out using the SPDIF protocol.
In this case your laptap should have a SPDIF out (optical or coax)
