SOLD Eva LDR based passive linestage incredible sound remote volume control
0 Members and 1 Guest are viewing this topic. Read 2665 times.
nicksgem10s
SOLD
Up for sale is my Eva which is the DIYparadise LDR based passive linestage with remote volume control.
The unit is in 9/10 condition and works perfectly.  The only small thing to note is one of the very small rubber footers has gone missing.  I will replace it with poster putty or a similar footer for the new owner.  I have been using it this way without any issue.
This bettered all preamps I have owned and auditioned.  This includes a very long list including some preamps in the $2,000-$5,000 range.
If your system is compatible with a passive preamp I do not see how you will achieve better sound.
Only reason for the sale is my new amp and speakers need an active preamp.
It also has a very small footprint and cool appearance along with remote volume control.
This version has one set of rca inputs and outputs.  Amazing sound quality.
$225 (firm) + shipping.  I will cover paypal fees.  SOLD
These are stock photos but they may be of my actual unit.  It looks exactly the same.
-Nick
« Last Edit: 1 Sep 2010, 12:35 am by nicksgem10s »
doug s.
  • makin' music
i can wouch for the sound quality of this one.  it's so good that i use it in between my much beloved highly modded melos ma3333r preamp and my amps, for the conwenience of its remote.  even tho my melos has a remote - the melos' remote is not wery ergonomically friendly as it is a true dual-mono preamp, and its remote doesn't track well channel to channel.  i feel it has actually improved the sonics, as the melos seems to sound best when its wolume pots are close to max'd out, which is where i now have them set.  this thing is completely transparent, imo.
even tho the asking price is close to what it was when new, it's still a freaking bargain, imo, especially as diyparadise no longer makes it; i had to buy the more spendy 3-input wersion, even tho i only needed a single input for my use.  someone should grab this, even if they use an active preamp.  (nick, if i were you, i'd keep this and try it w/whatever active you end up with - you may like it!   8) )
doug s.
Jon L
All right, I'll take it.  PM sent.
nicksgem10s
doug s.
I appreciate your comments Doug.  You are right that I probably should have kept it.  It bettered a $4-5k TVC in my system.  It has been sold.
Thanks to all that sent pms.
-Nick
