0 Members and 1 Guest are viewing this topic. Read 50244 times.
So what did you do? Have the trim pots at zero ohms or the highest setting? When read your pots what is the highest you can get? Mine only seem to get to 1.2K but I figure that is the circuit.
If you can come up with a variac, it is MUCH simpler, and safer. Also if you can fire up one channel, then the next.Russellc
Well, I just fixed my PS. I had my secondarys mixed I guess I should have her up and running soon!!
FWIW, a more ideal comparison is the F5 vs Aleph J, as the F5 is closer to being a complementary (push-pull) version of the Aleph J (single-ended). The F3 is single-ended but its quite a bit different design altogether. Still the F3 is single ended so the harmonic differences still apply.
I don't know anything about an ideal comparison. Ideal how? They are all apples to oranges. At least the AJ, F3 and ZV9 all use the same JFET... I think.
