0 Members and 1 Guest are viewing this topic. Read 11063 times.
Could I ask what the dimensions of the wings for the U baffle on the MAW 12 are?
From the looks of the passive components, and the associated drop in efficiency for the b200, I will have to change amps...
Making the design wider or taller doesn't change things much. But you are free to position the B 200 at any height you wish. In any case the baffle should end just above the driver. Rudolf
As for the components in the Xover for the woofer, it appears that both the cap and coil may be costly. Too bad I cannot just use the Xover in the Panny SAXR50, that would save me over $100!
The proposed XO doesn't include a zobel, so the 12db/octave target will not be realized. Be prepared to add a couple more passive components to correct for this.
IMO an electronic XO would be a better solution...
What is the thinking behind your advice to end the baffle just above the driver, please?
Only for clarification: A zobel (which should not be too costly) could be necessary with a tube amp for the B 200. For any SS amp the design target will be reached without a problem.
DSP solutions would be beyond the target of this thread IMHO.
I recall that the Reckhorn F1 might actually be a 12 db/oct Xover?
